Home > Technical > [FAQ] WARNING - DOES YOUR FRONT SUSPENSION KNOCK?
Page 10 of 32 <123 ... 91011 ... 303132>
Fingers crossed Steve... sounds like you have a half-decent dealer there too Thumbs Up
Post #186969 Fri Sep 05 2008 11:44am
chris
Germany 2008 Range Rover Sport TDV8 HSE Java Black
Hi Steve,
is it the dynamic response knocking ?
Or what is mentioned in the repair bulletin.
My RRS is still knocking here in Germany Mad ---------------------------------------------------------
RRS TDV8 MY 08.05 java black / alpaca
Post #187016 Fri Sep 05 2008 5:42pm
Steve in germany
I will get the full details when I go to the dealer on Monday morning, will post all the info I can get my hands on Thumbs Up Speed Limits! not where I live!
Back in a D3
Did have: RRS TDV8 2008.5MY
Did have: Q7 3.0TDi S-Line/Tech/Comms pack
Did Have: Disco3 HSE
Post #187017 Fri Sep 05 2008 5:50pm
Steve in germany
Dropped the car off first thing this morning, service manager thinks it will be finished today. They gave me a FL2 auto as a loaner, I quite like it. Speed Limits! not where I live!
Back in a D3
Post #187150 Mon Sep 08 2008 7:56am
Steve in germany
Ok car is back, and guess what, the knocking clanging noise has gone. The dealer told me it's all to do with the ACE and the anti-roll bar, they have basicaly replaced these parts. I think that is pretty much what everyone believes to be the problem, so hopefully the last I hear of it, well on my car anyway. Thats German efficiency for you Thumbs Up They don't mess about over here. Speed Limits! not where I live!
Back in a D3
Post #187245 Mon Sep 08 2008 3:36pm
Markos
Slovenia 2008 Range Rover Sport TDV8 HSE Java Black
I am very happy for you Steve hope it is gone for ever Thumbs Up Is there any possibility to get a repair bulletin? 2008 RRS TDV8 HSE, Java black, Alpaca,.....
Post #187276 Mon Sep 08 2008 8:39pm
chris
Dear Steve,
great to hear that.
What is the ACE. Is it the DR system.
And do you have a repair bulletin no. or something I could give to my dealer.
Because they are telling me that they cannot do anything / and or are not allowed from LR England to repair something.
because the knocking is from the DR system Mad
So it would be great to get more infos from you.
I am also in Germany....
Tks. a lot. ---------------------------------------------------------
Post #187277 Mon Sep 08 2008 8:39pm
Steve in germany
Will get the info for you tomorrow, will ask the dealer for the bulletin number. Speed Limits! not where I live!
Back in a D3
Post #187279 Mon Sep 08 2008 8:47pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
The TSB linked below was just issued here in North America, it addresses front or rear suspensions knocks on cars NOT fitted with Dynamic Response. It applies to both RRS and Disco/LR3, regardless of year of manufacture. Sorry if it's a duplicate post, but I quickly browsed this thread and couldn't find mention of it, plus sometimes we get things fixed a bit later here in the US... Laughing
http://rangerovers.net/forum/viewtopic.php?f=5&t=26705
Post #187301 Tue Sep 09 2008 2:08am
MAC
United Kingdom 2011 Range Rover Sport SDV6 HSE Orkney Grey
Can anyone confirm which fuse to remove to check if suspension noise is due to the dynamic response system? I checked the manual and it states fuse 23 in the engine compartment fuse box. I removed this and still have the same knocking noise. I just want to confifm this is the correct fuse before I go bask to the dealer yet again and am fobbed off with it being the "characteristic of the vehicle"
Thanks,
Mac
Post #187312 Tue Sep 09 2008 7:29am
Tim in Scotland
I see in that TSB that it mentions "Due to paint wear" - you would think that they would engineer something as important to the driving pleasure to be able to last a bit longer than wearing off a micron or two of paint! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #187326 Tue Sep 09 2008 8:33am
Steve in germany
OK went back in to my dealer earlier, the TSB they had was for cars without ACE, however like I said they had a Sport in a couple of weeks ago with the same problem, they have now rectified three cars, what i have done is attach the Job sheet for you Chris, hopefully you can take this into your dealer and they will give it a go, at least they could possibly call the meister at Striewe and get the info from them. Hope this helps. You can see a larger copy in my gallery.
Back in a D3
Post #187390 Tue Sep 09 2008 3:48pm
Josh
Anyone able to translate this Question What is ACE Question If it's the DR then your car has it Steve, so why would they use a repair for non ACE vehicles Confused
I had a chat with my local dealer today about this and they had no knowledge of this bulletin or even a new design of AR bushes Confused TDV6 - gone
TDV8 - gone
Post #187392 Tue Sep 09 2008 4:24pm
Tim in Scotland
ACE used to be fitted to Disco2 and was the accronym for Active Cornering Enhancement, what RRS has is a developement called ARM - Active Roll Mitigation.......................... basically it's a development of ACE 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #187398 Tue Sep 09 2008 4:40pm
Steve in germany
No, they have'nt used a repair from the TB which refers to non-ACE cars, what they have done is after consultation with LR and other dealers is come up with this fix, which has worked in 3 other cars. The parts replaced are the stabiliser arm and the rubber bushes and fixings. Speed Limits! not where I live!
Back in a D3
Post #187401 Tue Sep 09 2008 4:46pm
