![]() | Home > Technical > Engine Warning Light - Again |
sjdavies Member Since: 24 Oct 2007 Location: Spain Posts: 4 ![]() ![]() |
Hi there.
Could be the Valves. 2005 Zambezi TDV6 - Gone but not forgotten
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Did they check the MAF sensor? I can see how a bad sensor could cause the symptoms you are experiencing when you reach a certain speed. It could be a variety of things, though. |
MAF sensor sounds better than valves - that sounds very scary and expensive !!! |
sjdavies, what engine and model year is your Sport? S/C have had issues of reduced engine power under load in some 06s and 07s. There was a TSB issued about it - something about an auxiliary coolant pump for the supercharger being miswired at the factory - and I can try locating a copy, if that's your engine. |
MY SC is an 05 with the 4.4V8 engine, so thankfully not the pump issue.
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
sjdavies your RRS icon/profile indicates that you have a TDV6 HSE |
