Home > Technical > Engine Warning Light - Again |
sjdavies Member Since: 24 Oct 2007 Location: Spain Posts: 4 |
Hi there.
Tue Jul 29 2008 8:02pm |
Could be the Valves. 2005 Zambezi TDV6 - Gone but not forgotten
Tue Jul 29 2008 8:52pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Did they check the MAF sensor? I can see how a bad sensor could cause the symptoms you are experiencing when you reach a certain speed. It could be a variety of things, though. |
Tue Jul 29 2008 8:58pm |
MAF sensor sounds better than valves - that sounds very scary and expensive !!! |
Tue Jul 29 2008 9:13pm |
sjdavies, what engine and model year is your Sport? S/C have had issues of reduced engine power under load in some 06s and 07s. There was a TSB issued about it - something about an auxiliary coolant pump for the supercharger being miswired at the factory - and I can try locating a copy, if that's your engine. |
Tue Jul 29 2008 11:26pm |
MY SC is an 05 with the 4.4V8 engine, so thankfully not the pump issue.
Wed Jul 30 2008 8:06am |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 |
sjdavies your RRS icon/profile indicates that you have a TDV6 HSE ........on a S/C I doubt it will be the EGR valves then, (may not even have any on that engine). RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Wed Jul 30 2008 9:26am |
