![]() | Home > General > red diesel |
bex Member Since: 24 Mar 2008 Location: Abingdon Posts: 179 ![]() |
Dan,
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
With red diesel it would stain the fuel filters etc and if you ever use the car on the road again and get pulled over you could have a lot of explaining to do even if the car has normal fuel in it.
I believe it's exactly the same fuel as you'd get from a pump, so technically there's no reason why you couldn't use it.... but if you want to take that risk with HMCE then knock yourself out |
You could always buy a colour neurtaliser |
highbridgeflyer Member Since: 06 Aug 2006 Location: Midlands Posts: 113 ![]() ![]() |
You are obviously, like my bro-in-law, one of the nations poor farmers. |
BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324 ![]() ![]() |
I used to use ATF as an injector cleaner in my old 300tdi disco,
Rooleeds Member Since: 26 Sep 2006 Location: U.K. Posts: 43 ![]() ![]() ![]() |
I think there is a chemical maker that either shows up when they run it through their analysis, probably on a Gas Chromatograph or similar, (Im a geeky chemist).
You could always use Bio-diesel (to some extent).....currently 93p a litre around reading. I think the issue is the mix though on the TDV6/8 engines. That price is based on 100%. L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Red diesel is not the same as white diesel....just imagine the lowest grade unleaded petrol you can buy on a mexican forecourt and then you get the picture |
EX-X5! Member Since: 24 Sep 2007 Location: Midlands Posts: 237 ![]() ![]() ![]() |
My best mate tried to run his van on crisp and dry. It worked too for a while, then all of a sudden it didnt work. Says it all really.
If you're interested
![]() ![]() ![]() ![]() ![]() ![]() ![]() Not sure why, but that gave me a stitch....classic!! ![]() 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
do you think it could have been the properties of the "crisp and dry" as it says it doesn't cling to the chips like normal oil does |
Jonty Member Since: 11 Mar 2008 Location: Sat with my head in my hands wondering what the hell I'm doing Posts: 508 ![]() ![]() |
My brother in law works in quarries and goes through thousands of gallons of Red.
