![]() | Home > Off Topic > EXCEL SHEET RECOVERY - HELP |
Good luck with it... |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
Nick - this is a private client - I'm onsite at this new build project so unfortunately no IT dept - in fact I have become his IT dept today |
cyberjes Member Since: 12 Jan 2008 Location: Prague Posts: 167 ![]() ![]() |
R.I.P.
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Kaine, There is a facility in windows to recover previous versions of files under these circumstances. It's called "Shadow Copy Client". The only problem is, it is not activated by default but has to be configured. In the slim hope that your client may have this feature enabled try placing the mouse cursor over the file in question, right click once and look down the menu that appears. If the Shadow copy is enabled then one of the options available will be "Previous Versions" which you can then select from to recover the file. If he doesn't have "Shadow Copy" enabled then I'm afraid he's stuffed. Advise him to buy a cheap backup solution. Freecom do one for about £60 that is simply an external Hard Drive bundled with NTI backup software and works very well for Single users/small companies. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Thanks mate - he's now left to go get a back up drive and has arranged for some two of his staff to work over the weekend to remake the documents
Yep, They always learn after the fact! People don't seem to value their data until they lose it then they panic!! Crazy, Mad, Bonkers ![]() ![]() 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
is the shadow copy function part of Vista or is it availaible on XP |
Apple have a thing called Time Machine which rescues situations like this - now if only they made software for the Mac! |
VA - learnt about that software today - looks very good |
Yep It's available in XP. Just search for it using google and you'll find loads of help sites that talk you through activating it. Remember - GOOGLE is your friend ![]() 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
Kaine,
Hi Will,
NP.
Cornelius Vermuyden Member Since: 15 Aug 2006 Location: The Far Canal Posts: 190 ![]() ![]() |
Kaine Contrary to comments, Excel files are pretty easy to recover, at low cost (unless some erasing 37-pass overwrite has been used)
