Home > Off Topic > EXCEL SHEET RECOVERY - HELP |
Good luck with it...
Fri Apr 18 2008 12:23pm |
Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902 |
Nick - this is a private client - I'm onsite at this new build project so unfortunately no IT dept - in fact I have become his IT dept today
Fri Apr 18 2008 12:47pm |
cyberjes Member Since: 12 Jan 2008 Location: Prague Posts: 167 |
R.I.P.
Fri Apr 18 2008 2:04pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Kaine, There is a facility in windows to recover previous versions of files under these circumstances. It's called "Shadow Copy Client". The only problem is, it is not activated by default but has to be configured. In the slim hope that your client may have this feature enabled try placing the mouse cursor over the file in question, right click once and look down the menu that appears. If the Shadow copy is enabled then one of the options available will be "Previous Versions" which you can then select from to recover the file. If he doesn't have "Shadow Copy" enabled then I'm afraid he's stuffed. Advise him to buy a cheap backup solution. Freecom do one for about £60 that is simply an external Hard Drive bundled with NTI backup software and works very well for Single users/small companies. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Fri Apr 18 2008 2:27pm |
Thanks mate - he's now left to go get a back up drive and has arranged for some two of his staff to work over the weekend to remake the documents
Fri Apr 18 2008 2:32pm |
Yep, They always learn after the fact! People don't seem to value their data until they lose it then they panic!! Crazy, Mad, Bonkers Especially when backup solutions are so easy and cheap these days. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black |
Fri Apr 18 2008 2:54pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
is the shadow copy function part of Vista or is it availaible on XP |
Fri Apr 18 2008 5:13pm |
Apple have a thing called Time Machine which rescues situations like this - now if only they made software for the Mac! 2005 Zambezi TDV6 - Gone but not forgotten
Fri Apr 18 2008 6:25pm |
VA - learnt about that software today - looks very good |
Fri Apr 18 2008 6:27pm |
Yep It's available in XP. Just search for it using google and you'll find loads of help sites that talk you through activating it. Remember - GOOGLE is your friend 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black |
Sat Apr 19 2008 12:41pm |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 |
Kaine,
Sun Apr 20 2008 6:46pm |
Hi Will,
Sun Apr 20 2008 7:31pm |
NP.
Sun Apr 20 2008 8:51pm |
Cornelius Vermuyden Member Since: 15 Aug 2006 Location: The Far Canal Posts: 190 |
Kaine Contrary to comments, Excel files are pretty easy to recover, at low cost (unless some erasing 37-pass overwrite has been used)
Sun Apr 20 2008 10:23pm |
