Home > Technical > Bonnet opens whilst driving :shock: |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
On the way to work this morning my F g Bonnet sprang open!! Luckily there are 3 catches and the one on the passanger side held and I was able to stop and sort it. Couldn't see any obvious problems and it closed perfectly again. Luckily I was only doing about 40mph behind a truck! normally I'm going a lot quicker on that stretch of road - I hate to think what might have happened!
Fri Jan 25 2008 11:42am |
This was a reported problem with the earlier models.
Fri Jan 25 2008 12:00pm |
Alas, as Bobby rightly says, this has happened a few times. I'm not sure there was ever any fix other than to say that it is/was quite easy to mislocate the bonnet catches when closing the bonnet leaving it liable to coming back up once moving. Although it sounds like teaching you to suck eggs, the general advice was to ensure that the bonnet closed evenly by ensuring you closed it with both hands, each one towards either side and actually pushed it into place rather than letting it drop.
Fri Jan 25 2008 12:06pm |
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 |
You are not the only one with that problem. It also happened to me 2 weeks ago on RRS 2008 when I was driving approx. 120km/h on the highway and I could see the bonnet/spring lifting up slightly on the drivers side . Now i do not know if it was my mistake because I was just checking oil before but I think that i closed it properly-I did not drop the bonnet I closed it evenly with my hands.
Fri Jan 25 2008 2:23pm |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
This is a little disturbing.
Fri Jan 25 2008 3:21pm |
Interesting re the bonnet sensor - didn't know there was one of those
Fri Jan 25 2008 4:17pm |
The sensor is actually the bonnet alarm sensor. So if the bonnet isn't closed properly the alarm will sound when ever you try locking the car with the key fob.
Fri Jan 25 2008 4:21pm |
Thnx for the replies chaps - Just as a point of note, there was defo no bonnet open warning and the last time I had opened it myself was over a week ago and I am always careful to make sure it is closed properly. When it popped it was audible inside the car, " a metallic POP", as if a latch had slipped or been forced. When I ispected the latches I expected to find one had sheared or come loose in some way - but everything looks fine and the bonnet is closed and appears secure (as it was before). Car is due for 1st service in 2k so I'll get the dealer to check it out then. Unless it pops again ofcourse! then I'll be straight on to them. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Fri Jan 25 2008 4:24pm |
If the bonnet is popping without warning it may be worth dropping into your stealers before the service. You never know when it may happen again. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
Fri Jan 25 2008 4:29pm |
Too right - that could be downright dangerous...
Fri Jan 25 2008 4:31pm |
Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980 |
Not the sort of thing to take a chance on. Speed Limits! not where I live!
Fri Jan 25 2008 5:54pm |
Short Final Member Since: 14 Jan 2008 Location: Kent Posts: 12 |
............ multiple catches cause dealers problems. Two times coming back from a service my FFRR was only half latched.
Sat Jan 26 2008 6:39pm |
sportman Member Since: 25 Jul 2005 Location: UAE Posts: 550 |
what year u mean by earlier models? first production patch or what 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver SOLD-V8 Defender 90 |
Sun Jan 27 2008 7:33am |
Yes, 2005/2006. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Sun Jan 27 2008 10:25am |
