Home > Technical > Bonnet opens whilst driving :shock:
Page 1 of 3 123>
Endjin
Scotland
On the way to work this morning my F Censoredg Bonnet sprang open!! Shocked Luckily there are 3 catches and the one on the passanger side held and I was able to stop and sort it. Couldn't see any obvious problems and it closed perfectly again. Luckily I was only doing about 40mph behind a truck! normally I'm going a lot quicker on that stretch of road Whistle - I hate to think what might have happened!
Has anyone else had this happen on their RRS? Question 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #152847 Fri Jan 25 2008 11:42am
Bobby
This was a reported problem with the earlier models.
Thought they would have sorted it by now. Rolling Eyes
http://www.rrsport.co.uk/forum/topic60.html?highlight=bonnet Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #152855 Fri Jan 25 2008 12:00pm
Alas, as Bobby rightly says, this has happened a few times. I'm not sure there was ever any fix other than to say that it is/was quite easy to mislocate the bonnet catches when closing the bonnet leaving it liable to coming back up once moving. Although it sounds like teaching you to suck eggs, the general advice was to ensure that the bonnet closed evenly by ensuring you closed it with both hands, each one towards either side and actually pushed it into place rather than letting it drop.
As you say, could've been a bit more hairy than it was... Surprised
Post #152856 Fri Jan 25 2008 12:06pm
Markos
Slovenia 2008 Range Rover Sport TDV8 HSE Java Black
You are not the only one with that problem. It also happened to me 2 weeks ago on RRS 2008 when I was driving approx. 120km/h on the highway and I could see the bonnet/spring lifting up slightly on the drivers side Rolling Eyes . Now i do not know if it was my mistake because I was just checking oil before but I think that i closed it properly-I did not drop the bonnet I closed it evenly with my hands.
Hopefully it won´t happen again.... Bow down 2008 RRS TDV8 HSE, Java black, Alpaca,.....
Post #152884 Fri Jan 25 2008 2:23pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
This is a little disturbing. Confused
The digital display on the drivers binnacle should warn the driver if the bonnet, doors or tailgate are not closed properly. If the bonnet is not latched correctly and you are not getting the warning message it sounds as if the bonnet sensor is not doing its job.
Whenever you open and subsequently close the bonnet you should use two hands, placed approx shoulder width apart to ensure even force is used across the two bonnet catches. It is always worth double checking that the bonnet latches are engaged properly by trying to lift the bonnet at each corner above the headlamp unit. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #152894 Fri Jan 25 2008 3:21pm
Interesting re the bonnet sensor - didn't know there was one of those Thumbs Up
You should be able to test the sensor of course by deliberately not closing the bonnet and starting the car to see if you get an alarm.
Post #152913 Fri Jan 25 2008 4:17pm
TB
The sensor is actually the bonnet alarm sensor. So if the bonnet isn't closed properly the alarm will sound when ever you try locking the car with the key fob.
But I think it also doubles as the binnacle display sensor too. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #152917 Fri Jan 25 2008 4:21pm
Endjin
Scotland
Thnx for the replies chaps - Just as a point of note, there was defo no bonnet open warning and the last time I had opened it myself was over a week ago and I am always careful to make sure it is closed properly. When it popped it was audible inside the car, " a metallic POP", as if a latch had slipped or been forced. When I ispected the latches I expected to find one had sheared or come loose in some way - but everything looks fine and the bonnet is closed and appears secure (as it was before). Car is due for 1st service in 2k so I'll get the dealer to check it out then. Unless it pops again ofcourse! then I'll be straight on to them. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Post #152921 Fri Jan 25 2008 4:24pm
TB
If the bonnet is popping without warning it may be worth dropping into your stealers before the service. You never know when it may happen again. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #152928 Fri Jan 25 2008 4:29pm
Too right - that could be downright dangerous... Shocked
Post #152929 Fri Jan 25 2008 4:31pm
Steve in germany
Not the sort of thing to take a chance on. Shocked Speed Limits! not where I live!
Back in a D3
Did have: RRS TDV8 2008.5MY
Did have: Q7 3.0TDi S-Line/Tech/Comms pack
Did Have: Disco3 HSE
Post #152946 Fri Jan 25 2008 5:54pm
Josh
This happened to me once on my old TDV6, no warning on dash but could clearly see the bonnet trying to lift. Since then when I close it firmly with both hands I always give the corners a tug to make sure the latch has engaged properly. Fingers crossed.
Think part of the issue is that the bonnet is very light and therefore very flexable if the wind gets under the edge of it. TDV6 - gone
TDV8 - gone
Post #153015 Fri Jan 25 2008 10:32pm
Short Final
............ multiple catches cause dealers problems. Two times coming back from a service my FFRR was only half latched.
Stopped on the hard shoulder as I'd had enough excitement from my journey and re-latched. Dealers claim it was 'fine' when it was handed over. Thanks Guy Salmon (Aylesford) .......... ______________________________________________
It is the view from the office window that counts...
Post #153111 Sat Jan 26 2008 6:39pm
sportman
United Arab Emirates 2006 Range Rover Sport Supercharged Buckingham Blue
what year u mean by earlier models? first production patch or what 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver
SOLD-V8 Defender 90
Post #153154 Sun Jan 27 2008 7:33am
Bobby
Yes, 2005/2006. Smile Malaysia Boleh!
Post #153171 Sun Jan 27 2008 10:25am
Page 1 of 3 123>
