![]() | Home > Maintenance & Modifications > Got any top tips for solving niggles with an 08.5MY TDV8? |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
The seatbelt warning BONG can be disabled - Insert the buckle into its holder and the release immediately - in,out ,in,out,in,out,in,out............. etc etc in rapid sucsession [ no need to let belt retract ] If I remember it needs to be inserted/released several times BUT I havent heard if this is still the case on an 08.5 model year |
Keep us informed about the seatbelt as LR might have changed this feature in the 08.5MY 2005 Zambezi TDV6 - Gone but not forgotten
bermyandy Member Since: 09 Sep 2007 Location: London Posts: 336 ![]() ![]() |
Is the seatbelt fix a permanent one, or one you have to do everytime you turn the ignotion on (a la On the Go Sat nav input fix) |
Once you disable the bong, the bong is gone for good |
Hmm... need to redo the bong removal, as the bong still bongs when i thought it would have stopped bonging |
Have you done the in/out enough times? It needs to be 9 times... you'll see the seatbelt warning light go out on the binnacle on the 9th in/out. It could of course be though, that as mentioned above, it doesn't work on MY08.5 cars. |
To reactivate the bong just do the procedure again. 2005 Zambezi TDV6 - Gone but not forgotten
I guess you need some weight on the seat though? I did it on an empty seat, so no seat belt warning was showing |
sid Member Since: 21 Aug 2007 Location: northants Posts: 45 ![]() ![]() ![]() |
Key in ignition, turn to switch electrics on. Sit in seat and put buckle in the buckle lock 9 times within a minute. After the ninth time a bong will sound and it's sorted. Do the reverse to reset! "I want to die peacefully in my sleep like my grandfather.....
TheLynxEffect Member Since: 07 Nov 2007 Location: Midlands Posts: 38 ![]() ![]() ![]() |
Just got my good lady to try the whole 9 times thing whilst I was driving.... no joy.
It is possible that you have found an unintended 2008.5MY modification! Might be easier to drive round with whatever you normally carry on the front passenger seat, excluding your good lady that is!, in the foot well - at least if it is down there it cannot be launched into the dash or screen if you have to stop suddenly 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
NZHereIam Member Since: 26 May 2007 Location: Wellington Posts: 205 ![]() ![]() ![]() |
Or , alternativley, you could fasten the seat belt and place whatever items you want on the front seat? ![]() 06 RRS HSE ( in Wellington Dockyard, still waiting for release!!) 05 Jeep Cherokee LTD Edition |
949BFN Member Since: 16 Apr 2007 Location: Bloemfontein Posts: 59 ![]() ![]() ![]() |
I thing the "while I was driving" part is the problem. As far as I know, the ignition should be switched on, but the engine should NOT be running. 2010 Sport Supercharged with all options apart from TV and Extended leather (wish I had the latter) (Previously 2007 RRS S/C) |
BoldlyGo Member Since: 13 Jan 2006 Location: Surrey Posts: 216 ![]() ![]() |
I don't have this on my 06 TDV6 SE, is it a standard feature that I just have to activate ? P400e HSE Portofino Blue and Ivory Seats.. it's like a yacht!! Lexus traded in ..a total piece of crap Boldly now acquired - a Lexus RX 450hL BoldlyGone...Sep 15 MY16 RRS SDV6, HSE, Barolo Black, Espresso/Almond interior.. Best car ever & Drop dead gorgeous... sadly with fuel dilution headaches that became intolerable Arrived 2014. Oct - Lemoned March 2015- RRS SDV6 HSE Boldly Gone = Sold for 14k via Pistonheads - 2006 TDV6 SE Buck Blue/Almond int |
