Home > Maintenance & Modifications > Got any top tips for solving niggles with an 08.5MY TDV8?
TheLynxEffect
Hi all,
Just to say I've had my TDV8 for 4 days now and it's awesome! Amazed by the power delivery in such a vast car!
Unforuntately I was late getting to the dealers when I picked it up so literally paid for it and drove off without having time to sort out any 'dealer settings'.
The main one that is really gripping me is the passenger (and driver) seatbelt BONG!!! (as in the noise it makes rather than the student ornament!) If I put ANYTHING in the passenger seat then the seatbelt warner continueously winges at me!
I did a search on here and found that it can be turned off by buckling/unbuckling the seat belt 9 times.... tried that, no joy! Don't know if I did it correctly, ie do you have to let the belt retract all the way each time? Can you still use ths trick on the 08.5MY?!
The other pain is the 3 flash lane change indicators! Can I disable them or is it a dealer only setting? Just bugs me when wanting to do a quick lane change and it's still there flashing away!
I'm not fussy at all!!!
Cheers all.
Post #147919 Wed Dec 12 2007 9:14am
The seatbelt warning BONG can be disabled - Insert the buckle into its holder and the release immediately - in,out ,in,out,in,out,in,out............. etc etc in rapid sucsession [ no need to let belt retract ] If I remember it needs to be inserted/released several times BUT I havent heard if this is still the case on an 08.5 model year Confused
As for the 3 flash indicator --- I think that's a good thing and wouldn't want to turn it off .. not sure you can anyway?
Post #147921 Wed Dec 12 2007 9:31am
Keep us informed about the seatbelt as LR might have changed this feature in the 08.5MY 2005 Zambezi TDV6 - Gone but not forgotten
Post #147924 Wed Dec 12 2007 9:34am
bermyandy
2013 Range Rover Sport Supercharged Zermatt Silver
Is the seatbelt fix a permanent one, or one you have to do everytime you turn the ignotion on (a la On the Go Sat nav input fix)
Post #147986 Wed Dec 12 2007 12:34pm
Once you disable the bong, the bong is gone for good Very Happy
Post #147987 Wed Dec 12 2007 12:38pm
bermyandy
Hmm... need to redo the bong removal, as the bong still bongs when i thought it would have stopped bonging
Post #147994 Wed Dec 12 2007 1:05pm
Have you done the in/out enough times? It needs to be 9 times... you'll see the seatbelt warning light go out on the binnacle on the 9th in/out. It could of course be though, that as mentioned above, it doesn't work on MY08.5 cars.
Post #147995 Wed Dec 12 2007 1:06pm
To reactivate the bong just do the procedure again. 2005 Zambezi TDV6 - Gone but not forgotten
Post #148010 Wed Dec 12 2007 2:26pm
bermyandy
I guess you need some weight on the seat though? I did it on an empty seat, so no seat belt warning was showing
Post #148026 Wed Dec 12 2007 4:19pm
sid
England 2008 Range Rover Sport TDV8 HSE Java Black
Key in ignition, turn to switch electrics on. Sit in seat and put buckle in the buckle lock 9 times within a minute. After the ninth time a bong will sound and it's sorted. Do the reverse to reset! "I want to die peacefully in my sleep like my grandfather.....
Not screaming in terror like his passengers."
Post #148029 Wed Dec 12 2007 4:30pm
TheLynxEffect
Just got my good lady to try the whole 9 times thing whilst I was driving.... no joy.
I reckon she did it wrong to be honest but so far, not looking too hopefully. I'll have another try later on but I'll be peeved if Ford have decided to remove this trick.
Post #148033 Wed Dec 12 2007 7:01pm
Tim in Scotland
It is possible that you have found an unintended 2008.5MY modification! Might be easier to drive round with whatever you normally carry on the front passenger seat, excluding your good lady that is!, in the foot well - at least if it is down there it cannot be launched into the dash or screen if you have to stop suddenly 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #148035 Wed Dec 12 2007 7:24pm
NZHereIam
New Zealand 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Or , alternativley, you could fasten the seat belt and place whatever items you want on the front seat? Thumbs Up If you dont live on the EDGE, you are taking up too much space!!!!!!!!!!!!!
06 RRS HSE ( in Wellington Dockyard, still waiting for release!!)
05 Jeep Cherokee LTD Edition
Post #148036 Wed Dec 12 2007 7:29pm
949BFN
South Africa 2007 Range Rover Sport Supercharged Chawton White
I thing the "while I was driving" part is the problem. As far as I know, the ignition should be switched on, but the engine should NOT be running. 2010 Sport Supercharged with all options apart from TV and Extended leather (wish I had the latter) (Previously 2007 RRS S/C)
Post #148161 Thu Dec 13 2007 2:46pm
BoldlyGo
I don't have this on my 06 TDV6 SE, is it a standard feature that I just have to activate ? P400e HSE Portofino Blue and Ivory Seats.. it's like a yacht!!
Lexus traded in ..a total piece of crap
Boldly now acquired - a Lexus RX 450hL
BoldlyGone...Sep 15 MY16 RRS SDV6, HSE, Barolo Black, Espresso/Almond interior.. Best car ever & Drop dead gorgeous... sadly with fuel dilution headaches that became intolerable
Arrived 2014. Oct - Lemoned March 2015- RRS SDV6 HSE
Boldly Gone = Sold for 14k via Pistonheads - 2006 TDV6 SE Buck Blue/Almond int
Post #148277 Fri Dec 14 2007 9:24am
