Home > Technical > Filled up my TDV6 with gasoline...! help!
Page 1 of 3 123>
Tay_pt
Portugal 2006 Range Rover Sport TDV6 HSE Java Black
Well... Wednesday was one of those days I shouldn't got out of bed.
After a lousy morning, I stopped at the gas station with my mind elsewhere and manage to fill my TDV6 tank with 55 litre of gasoline before I notice the mistake.
Before filling up, my tank had left about a 1/4 of diesel inside. I never turn the engine on and immediately called the LR dealer.
This is when things start to be even more awkward. They told me that this was a very complex situation and that I should tow the car there and they where going to see what they could do about it.
I had a similar experience several years ago with a Mercedes ML, and everything was very fast and efficient. The 24h support car went directly to the gas station and purge the fuel right there. I was ready to go in an hour or so.
When I arrived to the LR dealer they seemed very concerned and told me that eventually they had to take of the fuel tank to purge the gas. I found this to be completely absurd. Surely there must be some easier way to get the fuel out.
Now I’m still waiting to know what they are going to do, but I’m not buying this tank out thing.
Does any body here had a similar problem? Any ideas to what should be done, considering that I never turn the engine on and there was plenty of diesel inside the tank so gas shouldn’t have got to any tube or engine part.
Any help is appreciated….
Post #145421 Fri Nov 16 2007 11:21am
MAW
I'd have thought it could be pumped out easily enough Confused
Post #145427 Fri Nov 16 2007 11:45am
Tay_pt
Me also, but apparently there’s some kind of device inside the tank feed tube that prevents a burglar from pumping out gas. This is a clever idea… as long you design some other way of purging the fuel out, besides taking out the whole tank!
Post #145430 Fri Nov 16 2007 12:04pm
RAD
Scotland 2009 Range Rover Sport TDV8 HSE Stornoway Grey
If you haven't started the car, then you can get the tank drained, there are specialist vans in the UK that do nothing apart from sorting out the problem.
However, if you have started it, they won't drain the fuel on the spot but can arrange to take the car to your dealer, and if you are especially lucky, they will be able to drain the tank and clean the hoses, purge the fuel from pumps and replace the filters.
If its gone through to the engine........grovel to your insurance company, they may look kindly upon you because you may end up with a bill for as much as £4k. ('Sad') .
There is absolutely no substitute for a genuine lack of preparation.
TDV8 HSE MY10 with pretty much everything including a vase of daffs on the back shelf, tropical fish collection in the centre console, hamsters in the spare tyre and finally sheep on the passenger seats.....for weight distribution, what else??
Post #145431 Fri Nov 16 2007 12:13pm
Tay_pt
Thanks RAD,
I didn’t start the engine. I even took extra car to turn the key just to turn off the park brake, and immediately turn it off to prevent some kind of pre-pumping or something like that.
Has you said, there must be some kind of drain mechanism.
The LR dealer hover here is known for their lousy service. Everyone complains about it. There are even some ppl that drive more then 100km to go to another dealer. I just want to be informed so I don’t take any crap from them.
So if anyone had this problem, please tell me what you did to solve it.
Once again, thank you all.
Post #145432 Fri Nov 16 2007 12:26pm
Bad luck Tay_Pt - this can happen to the best of us. At least you didn't start the engine - so you face the least amount of work/money to get it sorted. I'm not sure of the RRS, but I know of a friend's Freelander 1 that this happened to (although he did run the engine before realising what he'd done) and that cost him a LOT of money to rectify.
Post #145433 Fri Nov 16 2007 2:01pm
Tim in Scotland
Cost is usually a new fuel system and engine because LR reckons that the benzine in the gas ruins the seals in the common rail diesel system, which operates at some hugely high pressure so they start you from scratch with new mechanicals and fuel system. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #145447 Fri Nov 16 2007 2:45pm
Bobby
This is on the Service Bulletin that was issued on 13 June 2006..
Accidentally Filling Diesel Vehicles with Gasoline
Vehicle incorrectly fueled and the ignition switch has not been turned to the 'on' position:
1 . Referring to relevant section in the workshop manual, drain the fuel tank.
2 . Remove the fuel tank assembly.
3 . Remove pump/sender module and invert to drain excess fuel.
4 . Remove all traces of residual fuel within the tank using clean absorbent cloth/paper.
5 . Flush pump/sender module with clean diesel
6 . Reassemble pump/sender module to fuel tank and install to vehicle.
7 . Fully fill fuel tank with clean diesel.
8 . Road test the vehicle.
9 . Return vehicle to customer.
...not sure if there's anything recent. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #145580 Sat Nov 17 2007 6:15am
Tim in Scotland
Note that it isn't a case of starting the engine, it says above "turned to the ON position" That is position 1 in the sart procedure, as the high pressure fuel pump starts then in anticipation of the driver starting up. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #145581 Sat Nov 17 2007 8:21am
Bobby
Yes, Tim.
This procedure is for a situation where the ignition switch has NOT been turned to the ON position.
I think Tay_pt said he "never turn the engine on...". Malaysia Boleh!
Post #145585 Sat Nov 17 2007 9:57am
Bobby
Okay. If he has turned the key BUT did not start the vehicle...
Vehicle incorrectly fueled and Ignition switch has been turned to the 'on' position:
5 . Flush pump/sender module with clean diesel.
6 . Remove fuel filter and discard.
7 . Disconnect fuel supply to high-pressure pump.
8 . Flush fuel housing and all fuel lines (inc. fuel return) with clean diesel.
9 . Reassemble pump/sender module to fuel tank and install to vehicle.
10 . Install new fuel filter.
11 . Fully fill fuel tank with clean diesel.
12 . Road test vehicle checking for normal engine operation and no stored diagnostic trouble codes are logged.
13 . Return vehicle to customer
Hope this will clear up any doubts. Malaysia Boleh!
Post #145586 Sat Nov 17 2007 10:05am
Tay_pt
Well thank very much guys for all the info. It was exactly this I was searching for.
Indeed they charge me the fuel tank disassembly, tubes cleaning and a new fuel filter.
The total cost was 247€ + 21% vat... totaling 300€! Crying or Very sad
This will certainly keep me very concentrated every time I go to the gas station for the next years! Confused
Post #146229 Thu Nov 22 2007 7:06pm
Endjin
Scotland
Glad to hear you got it sorted Tay_pt Very Happy
At least you had the good sense not to start the engine - It could have been much more expensive if you had! Thumbs Up 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #146230 Thu Nov 22 2007 7:11pm
300 Euro is a lot better than 10x that if you needed a new engine etc... good outcome Very Happy
Post #146296 Fri Nov 23 2007 12:41pm
Good result TBH - could have been a lot worse. 2005 Zambezi TDV6 - Gone but not forgotten
Post #146298 Fri Nov 23 2007 12:45pm
Page 1 of 3 123>
