![]() | Home > Technical > Filled up my TDV6 with gasoline...! help! |
Tay_pt Member Since: 16 Mar 2007 Location: Porto Posts: 55 ![]() ![]() ![]() |
Well... Wednesday was one of those days I shouldn't got out of bed.
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
I'd have thought it could be pumped out easily enough |
Me also, but apparently there’s some kind of device inside the tank feed tube that prevents a burglar from pumping out gas. This is a clever idea… as long you design some other way of purging the fuel out, besides taking out the whole tank! |
Thanks RAD,
Bad luck Tay_Pt - this can happen to the best of us. At least you didn't start the engine - so you face the least amount of work/money to get it sorted. I'm not sure of the RRS, but I know of a friend's Freelander 1 that this happened to (although he did run the engine before realising what he'd done) and that cost him a LOT of money to rectify. |
Cost is usually a new fuel system and engine because LR reckons that the benzine in the gas ruins the seals in the common rail diesel system, which operates at some hugely high pressure so they start you from scratch with new mechanicals and fuel system. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
This is on the Service Bulletin that was issued on 13 June 2006..
Note that it isn't a case of starting the engine, it says above "turned to the ON position" That is position 1 in the sart procedure, as the high pressure fuel pump starts then in anticipation of the driver starting up. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Yes, Tim. This procedure is for a situation where the ignition switch has NOT been turned to the ON position. I think Tay_pt said he "never turn the engine on...". Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Okay. If he has turned the key BUT did not start the vehicle...
Well thank very much guys for all the info. It was exactly this I was searching for.
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Glad to hear you got it sorted Tay_pt |
300 Euro is a lot better than 10x that if you needed a new engine etc... good outcome |
Good result TBH - could have been a lot worse. 2005 Zambezi TDV6 - Gone but not forgotten
