Home > Technical > Filled up my TDV6 with gasoline...! help! |
Tay_pt Member Since: 16 Mar 2007 Location: Porto Posts: 55 |
Well... Wednesday was one of those days I shouldn't got out of bed.
Fri Nov 16 2007 11:21am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
I'd have thought it could be pumped out easily enough |
Fri Nov 16 2007 11:45am |
Me also, but apparently there’s some kind of device inside the tank feed tube that prevents a burglar from pumping out gas. This is a clever idea… as long you design some other way of purging the fuel out, besides taking out the whole tank! |
Fri Nov 16 2007 12:04pm |
Thanks RAD,
Fri Nov 16 2007 12:26pm |
Bad luck Tay_Pt - this can happen to the best of us. At least you didn't start the engine - so you face the least amount of work/money to get it sorted. I'm not sure of the RRS, but I know of a friend's Freelander 1 that this happened to (although he did run the engine before realising what he'd done) and that cost him a LOT of money to rectify.
Fri Nov 16 2007 2:01pm |
Cost is usually a new fuel system and engine because LR reckons that the benzine in the gas ruins the seals in the common rail diesel system, which operates at some hugely high pressure so they start you from scratch with new mechanicals and fuel system. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Nov 16 2007 2:45pm |
This is on the Service Bulletin that was issued on 13 June 2006..
Sat Nov 17 2007 6:15am |
Note that it isn't a case of starting the engine, it says above "turned to the ON position" That is position 1 in the sart procedure, as the high pressure fuel pump starts then in anticipation of the driver starting up. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Nov 17 2007 8:21am |
Yes, Tim. This procedure is for a situation where the ignition switch has NOT been turned to the ON position. I think Tay_pt said he "never turn the engine on...". Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Sat Nov 17 2007 9:57am |
Okay. If he has turned the key BUT did not start the vehicle...
Sat Nov 17 2007 10:05am |
Well thank very much guys for all the info. It was exactly this I was searching for.
Thu Nov 22 2007 7:06pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Glad to hear you got it sorted Tay_pt
Thu Nov 22 2007 7:11pm |
300 Euro is a lot better than 10x that if you needed a new engine etc... good outcome
Fri Nov 23 2007 12:41pm |
Good result TBH - could have been a lot worse. 2005 Zambezi TDV6 - Gone but not forgotten
Fri Nov 23 2007 12:45pm |
