![]() | Home > General > land rover customer support e-mail |
lradvice@landrover.com is the email, but the "top end line manager" won't want to get involved unless you've followed the usual escalation process. |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
This is the biggest problem......trying to find someone to bellyache to. It is hard to get past the first line of defence with LR. Perhaps find out where they are located and just walk in there! RRS TDV6 Bluetooth, VR, Roof ![]() |
The approach is fair enough though - using the "write to the CEO" approach as your first line of attack all guns blazing isn't really going to get you anywhere. The higher echelons of management may be ultimately responsible for service provided but they can't spend all day dealing directly with customer's problems, otherwise they'd never have any time to fix them strategically. |
autolines Member Since: 01 Dec 2006 Location: blackpool Posts: 21 ![]() ![]() |
Thanks guys,
Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355 ![]() ![]() ![]() |
I think to be fair autolines this new type of convertor from ZF with all the new torsional damping in is catching some OE people out. You need to remember that the transmission also has later build specs to go with it and some on here including canaryman have had the later one fitted that you mention and no different on the car to the old one. I hope it sorts yours out.
AL, what are the symptoms of your steering shimmer? There are two quite separate ones; 1) First one is due to wheel balance or more precisely the stock steering rack being unable to damp any residual wheel imbalance. This has been rectfied with an upgraded sterring rack. 2) The second was a raspy/ vibration feel through the steering wheel between gearchanges and under load. I also had this one and had my torque convertor replaced which did not fix the prob. It ended up being a misalignment in the front diff which wore out a bearing. This was discovered after replacement of front wheels, torque convertor, prop shafts and front hubs. Just a bit concerned you maybe pinning your hopes on a torque convertor which, in my case, was not the answer to the vibration RRS TDV6 Bluetooth, VR, Roof ![]() |
