Home > Maintenance & Modifications > Chipping
Page 9 of 13 <123 ... 8910 111213>
LRtuning
2006 Range Rover Sport Supercharged Cairns Blue
RRMAD
You've lost me totally now Wink Chips with everything
Post #11220 Mon Jan 23 2006 8:29pm
noddy and bigears
i give up
TC will ring you tomorrow to book car in if thats ok i dont seem to be able to get straight answers anywhere else much you seem to be knowledgable and upfront about what you do and how you do it this post has had 120 replies and 4607 veiws if some of the other companys cannot see the potential sales and advertsing they would get from just replying to some of the questions that have been raised and promoting there product all i can say is if someone like you will take the time to read and answer the questions that are asked and take the flack that is aimed at you then you must REALLY belive in your product as the everest advert stated FORGET THE REST FIT THE BEST .... do i get discount Exclamation Wink thanks graham
Post #11222 Mon Jan 23 2006 8:46pm
LRtuning
Ta Wink Chips with everything
Post #11234 Tue Jan 24 2006 1:19am
JE Engineering
turbochip wrote:
Josh,
I'm happy to prove it to you....let me know if you can get to central London and I'll happily arrange a test drive via a LR dealer who uses TC as their 'in house' tuning company.
Noddy,
Our conversion is undetectable to all LR diagnostics and thank you for investigating the JE option...they are quite clever at using words to 'put people off the scent'...they do indeed use a computer to upgrade the ecu but so do I...only difference is that TC do it by OBD and JE open the ecu...funny how they still fail to mention that FACT!! Wink
ps Come on Jonathan (MD at JE) open your wallet and let's do a deal Wink
We are tuning via obd now.
As for LR diagnostics, i cant think of a way this machine would know that the ecu had been tuned.
It is quite possible for LR diagnostics too overwrite our tune back too standard, i have been working on a way too disable this feature however this would then make it obvious that the ecu had been tuned.
A catch 22 situation.
Post #11247 Tue Jan 24 2006 9:04am
LRtuning
How long does it take for you to upload your tune into the car? Chips with everything
Post #11248 Tue Jan 24 2006 9:10am
Biggles
I know this is slightly off topic, but I have had experience of JE parts and found them to be excellent . Fitted a chip and intercooler for my old P38A and the difference it gave the car was outstanding. I would use them again but this time around turbochip met my needs better.
Morale of the story, Horses for course's. Wink Its out there somewhere. Second V10 Treg on the drive at the moment.
Post #11250 Tue Jan 24 2006 9:26am
LRtuning
Biggles,
I agree they are v good at the 'older' LR products but now we've moved into the arena and pride ourselves not only on the quality of our product but on our customer service too Wink Chips with everything
Post #11253 Tue Jan 24 2006 9:50am
Josh
TC and JE,
Pardon my ignorance yet again, but does the "Catch 22" that JE describes apply to all modifications to the Ecu by any tuning company? TDV6 - gone
TDV8 - gone
Post #11266 Tue Jan 24 2006 1:21pm
LRtuning
All tuning companies who 'flash' update an ecu via the OBD or re-chip run the slight risk that the manufacturer could update an ecu and 'remove' the upgrade without knowing.
We could stop this process happening as JE suggest but if we did the LR diagnostics would report a canbus communication error.
In 6 years I have only had this happen to a peugeot 407 when it was recalled by the Peugeot for a cold start problem.
LR dealers do not routinely update the engine management ecu and if, and its a big 'IF', they did we would happily re upgrade an ecu for no charge.
We've done 270 TDV6 engines over the last 14 months and we havent had any issues whatsoever. Chips with everything
Post #11273 Tue Jan 24 2006 1:32pm
Josh
TC,
Thank you. TDV6 - gone
TDV8 - gone
Post #11275 Tue Jan 24 2006 1:37pm
JE Engineering
This is of more concern too vehicles in germany where they can use the vehicles top speed but LR have released updates for the TDV6 engine ecu, the update was mostly smoothing of the speed limiter cut-in and increase the speed limiter on some models. (this was due too brochure numbers being higher that the vehicle was actually limited too)
LR diagnostics now default too these later tunes when reprograming TDV6 ecu's, I dont belive the dealer is required too do these updates unless requested (this is probly only for german dealers)
It however makes no difference, like turbochip said 270 ecu's and no comebacks.
Post #11302 Tue Jan 24 2006 5:22pm
Mikey
I am not sure if this was mentioned before, is there a chip solution for gas powered U.S. spec vehicles? If so, what kind of performance gains should one expect on a Sport S/C?
Post #11307 Tue Jan 24 2006 6:06pm
PaulB
Post #11308 Tue Jan 24 2006 6:15pm
PaulB
Post #11309 Tue Jan 24 2006 6:16pm
LRtuning
I thought they were telling people last week they could do it via OBD???
Thats old news Paul...or is just a bit of spin Wink
Are you paying full price Paul....incidentally what do they charge? Chips with everything
Post #11310 Tue Jan 24 2006 6:21pm
