![]() | Home > Maintenance & Modifications > 22'' wheels - Tyre pressue |
mp3madness Member Since: 25 Apr 2007 Location: AUSTRALIA Posts: 42 ![]() |
I was told 42-44psi for my Toyo 285/35/22 |
NickM Member Since: 15 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
Thanks very much mate - mine are Toyo's too - just got to get in the routine of checking them every few weeks - my last car had sensors and I never bothered checking them!! |
Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434 ![]() ![]() ![]() |
Does anyone know if 265 35 22's are different? I had asked before but with no response.
I'd check with the local distributor of your particular brand of tyre they would probably be the most reliable people to ask. |
drevs Member Since: 04 Sep 2006 Location: USA Posts: 43 ![]() ![]() |
rec'd tire pressures are on your drivers door latch area. apparently the tire pressure is specific to the vehicle, not the wheel tire combo. |
Thanks Drevs
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 ![]() ![]() ![]() |
The tyre presures are DEFINATELY specific to tyre/wheel size, just look at any factory sticker and it shows different pressures for different wheels and tyres (obviously they wont show you the combo for 22's |
That's what I thought too. ViewWise brings up a good point; your other vehicles may require different pressures based on intended use or possible tire wheel combos. LR, however, rec's the same pressure for all wheel/tire combos (check your sticker). Also, these recommendations are indeed specific to the vehicle (ie: you're supposed to run 42 psi in your 22's when they're on the RRS, but perhaps not when you swap them onto your 650i). |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
I think the tyre pressure stickers on the door are country specific. Here in the US, we get a sticker with a single recommended inflation pressure, 38F/42R, for all styles of factory wheels - except the compact spare, of course (see picture below.) I believe in Europe they list recommended pressure for both light loads (driver only, so lower PSI) and full loads (passengers, luggage, morbidly obese drivers, higher PSI.) For that same reason, newer RRS with TPMS in those countries should have a toggle switch on the center console for the TPMS module, to allow switching between light load PSI and heavy load PSI monitoring without false alarms thrown on the dash. In the US, we have no such toggle switch. I guess that's because we are ALL morbidly obese around here.
Umberto over here we have tyre pressure stickers like that but with only the top box on them - you guys seem to get a huge choice of tyres/ pressures compared to us! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Not really... I don't even know why they bother listing 17" and 18" tires, since we can't get either here. And they are just listing the same wheels twice, first with front pressure, than again with rear pressure... In addition to morbidly obese, I guess they also think we are dumb and can't read columns. |
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
I think our average 20" wheel load rating of four adults and no particular luggage states 36F and 44R. Which is what I run on (assuming I'm correct...too dark to check now). I may have to edit this later ![]() Seems a little strange that the pressures should be country related if the tyre and wheel size is the same. ![]() TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
