Home > Maintenance & Modifications > 22'' wheels - Tyre pressue
NickM
Because these are not factory wheels, does anyone have an idea as to what tyre pressure my tyres should be on 22'' Stormers? Thanks for any help...
Post #163213 Wed Apr 02 2008 7:52pm
mp3madness
I was told 42-44psi for my Toyo 285/35/22
Post #163245 Thu Apr 03 2008 3:52am
NickM
Thanks very much mate - mine are Toyo's too - just got to get in the routine of checking them every few weeks - my last car had sensors and I never bothered checking them!!
Post #163250 Thu Apr 03 2008 8:08am
Jonathan
England 2012 Range Rover Sport SDV6 Autobiography Fuji White
Does anyone know if 265 35 22's are different? I had asked before but with no response.
Cheers Jaguar XKR Convertible
MY 2012 Range Rover Sport TDV6 Autobiography in Fujian White....Mmmmmmm
Range Rover Evoque 2.2 Prestige in white - gone
Porsche Boxster S White with lots of extras! Gone
Lotus Elise 2011 Touring for sunny days - gone!
Previously....
RRS TDV8 Black 57 Plate
645ci
Jag XKR Convertible (my wife still loves this car!)
BMW 530i
BMW 328i (I loved this car)
Golf R32
Post #163366 Fri Apr 04 2008 8:17am
mp3madness
I'd check with the local distributor of your particular brand of tyre they would probably be the most reliable people to ask.
Post #163442 Fri Apr 04 2008 2:22pm
drevs
2006 Range Rover Sport Supercharged Vesuvius Orange
rec'd tire pressures are on your drivers door latch area. apparently the tire pressure is specific to the vehicle, not the wheel tire combo.
Post #164279 Wed Apr 09 2008 8:13pm
Jonathan
Thanks Drevs
I thought they would be specific to the tyre/wheel - will check later.
J Jaguar XKR Convertible
Previously....
645ci
BMW 530i
Golf R32
Post #164329 Thu Apr 10 2008 8:49am
ViewWise
The tyre presures are DEFINATELY specific to tyre/wheel size, just look at any factory sticker and it shows different pressures for different wheels and tyres (obviously they wont show you the combo for 22's Laughing ). The vehicle plays a little hand in it (ie youd need more pressure in a 3 tonne car than a 2 tonne car) which is also why your supposed to have different pressures if your fully loaded. I remember the S class even having a different set of pressures if you plan to do 130mph+ when i took it to france.
Post #164365 Thu Apr 10 2008 12:51pm
drevs
Jonathan wrote:
Thanks Drevs
That's what I thought too. ViewWise brings up a good point; your other vehicles may require different pressures based on intended use or possible tire wheel combos. LR, however, rec's the same pressure for all wheel/tire combos (check your sticker). Also, these recommendations are indeed specific to the vehicle (ie: you're supposed to run 42 psi in your 22's when they're on the RRS, but perhaps not when you swap them onto your 650i).
Post #164450 Fri Apr 11 2008 1:11am
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
I think the tyre pressure stickers on the door are country specific. Here in the US, we get a sticker with a single recommended inflation pressure, 38F/42R, for all styles of factory wheels - except the compact spare, of course (see picture below.) I believe in Europe they list recommended pressure for both light loads (driver only, so lower PSI) and full loads (passengers, luggage, morbidly obese drivers, higher PSI.) For that same reason, newer RRS with TPMS in those countries should have a toggle switch on the center console for the TPMS module, to allow switching between light load PSI and heavy load PSI monitoring without false alarms thrown on the dash. In the US, we have no such toggle switch. I guess that's because we are ALL morbidly obese around here.
Post #164645 Fri Apr 11 2008 10:15pm
Tim in Scotland
Umberto over here we have tyre pressure stickers like that but with only the top box on them - you guys seem to get a huge choice of tyres/ pressures compared to us! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #164648 Fri Apr 11 2008 10:19pm
umbertob
Not really... I don't even know why they bother listing 17" and 18" tires, since we can't get either here. And they are just listing the same wheels twice, first with front pressure, than again with rear pressure... In addition to morbidly obese, I guess they also think we are dumb and can't read columns.
Post #164652 Fri Apr 11 2008 10:22pm
Tim in Scotland
Rolling with laughter Rolling with laughter 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #164653 Fri Apr 11 2008 10:24pm
Laughing
Post #164654 Fri Apr 11 2008 10:25pm
Josh
I think our average 20" wheel load rating of four adults and no particular luggage states 36F and 44R. Which is what I run on (assuming I'm correct...too dark to check now). I may have to edit this later Embarassed
Seems a little strange that the pressures should be country related if the tyre and wheel size is the same. Confused TDV6 - gone
TDV8 - gone
Post #164661 Fri Apr 11 2008 11:25pm
