![]() | Home > Tips & Tricks > [FAQ] How to change your brake pads |
nathanh1 Member Since: 03 Aug 2010 Location: Southampton Posts: 151 ![]() ![]() |
done mine myself and no they dont need front and rear together...
This may help you guys as well.
Macdaddy Member Since: 12 May 2012 Location: NW Posts: 101 ![]() |
Just thought i'd say thanks |
RRS-Spy Member Since: 01 Nov 2011 Location: London Posts: 169 ![]() ![]() ![]() |
I am looking to change the pads on my front brembo brakes and this guide is really useful.
Nothing extra needed when i did it, You only need the sensor too if yours has triggered the light on the dash. *EDIT... realise this post is a bit old now however i only got email notification today about a reply lol TDV8 RRS HST in Java - Gone TDV6 RRS Autobiography in Bali blue - Gone TDV6 RRS Autobiography Dynamic - Current |
Simon58 Member Since: 01 Jun 2012 Location: Wiltshire Posts: 89 ![]() ![]() ![]() |
Great info Macdaddy, thanks helped me out a lot today, the brake pad warning light came on today, used this to change my front pads, now the dash light is staying on so I suppose I have to change the cable too? About to get into a sport |
RR-moggle Member Since: 16 Aug 2014 Location: Leeds Posts: 8 ![]() ![]() ![]() |
Nice |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
Did you also measure rotor thickness - anyone know what spec is for that ? If rotor is pretty smooth with no big ridges on outer edge it is probably OK to just change pads - but I thought you should turn rotor (if it is in spec still) or replace - with pads - if rotor is showing signs of wear ...
Nuclear Red Member Since: 09 Oct 2014 Location: Surrey Posts: 7 ![]() ![]() ![]() |
I would use axle stands on hard ground as well as a trolley jack to to the lift.
nicka113 Member Since: 16 Jan 2012 Location: Essex Posts: 20 ![]() ![]() ![]() |
Is this the same for front and back? |
Backs are the same as in the brake bible (see link below) Bodsys Brake Bible
amuquet Member Since: 05 Apr 2016 Location: London Posts: 3 ![]() ![]() |
Thank you. This will come in handy. |
jatin22aug Member Since: 21 Apr 2016 Location: London Posts: 3 ![]() ![]() |
Thanks |
