Home > Tips & Tricks > [FAQ] How to change your brake pads |
nathanh1 Member Since: 03 Aug 2010 Location: Southampton Posts: 151 |
done mine myself and no they dont need front and rear together...
Mon Aug 15 2011 6:58pm |
This may help you guys as well.
Mon Nov 14 2011 1:50pm |
Macdaddy Member Since: 12 May 2012 Location: NW Posts: 101 |
Just thought i'd say thanks
Tue Apr 09 2013 3:15pm |
RRS-Spy Member Since: 01 Nov 2011 Location: London Posts: 169 |
I am looking to change the pads on my front brembo brakes and this guide is really useful.
Tue Jun 25 2013 11:41am |
Nothing extra needed when i did it, You only need the sensor too if yours has triggered the light on the dash. *EDIT... realise this post is a bit old now however i only got email notification today about a reply lol TDV8 RRS HST in Java - Gone TDV6 RRS Autobiography in Bali blue - Gone TDV6 RRS Autobiography Dynamic - Current |
Tue Jun 25 2013 12:38pm |
Simon58 Member Since: 01 Jun 2012 Location: Wiltshire Posts: 89 |
Great info Macdaddy, thanks helped me out a lot today, the brake pad warning light came on today, used this to change my front pads, now the dash light is staying on so I suppose I have to change the cable too? About to get into a sport |
Fri Aug 09 2013 3:36pm |
RR-moggle Member Since: 16 Aug 2014 Location: Leeds Posts: 8 |
Nice |
Sat Aug 16 2014 9:21pm |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 |
Did you also measure rotor thickness - anyone know what spec is for that ? If rotor is pretty smooth with no big ridges on outer edge it is probably OK to just change pads - but I thought you should turn rotor (if it is in spec still) or replace - with pads - if rotor is showing signs of wear ...
Thu Sep 11 2014 3:22am |
Nuclear Red Member Since: 09 Oct 2014 Location: Surrey Posts: 7 |
I would use axle stands on hard ground as well as a trolley jack to to the lift.
Mon Oct 27 2014 3:39pm |
nicka113 Member Since: 16 Jan 2012 Location: Essex Posts: 20 |
Is this the same for front and back? |
Tue Apr 05 2016 9:21am |
Backs are the same as in the brake bible (see link below) Bodsys Brake Bible
Tue Apr 05 2016 10:12am |
amuquet Member Since: 05 Apr 2016 Location: London Posts: 3 |
Thank you. This will come in handy. |
Tue Apr 05 2016 11:51am |
jatin22aug Member Since: 21 Apr 2016 Location: London Posts: 3 |
Thanks |
Sat Dec 29 2018 8:30pm |
