Home > Tips & Tricks > [FAQ] How to change your brake pads
nathanh1
done mine myself and no they dont need front and rear together...
Generally front @ 22-25k and rear @ 30k!
Geniune parts from LR very reasonable @ around 100 front or rear pair including the new sensor and brackets!
anyone else stuggle getting the front sensor to stay in the Censored caliber? Bow down
Post #309948 Mon Aug 15 2011 6:58pm
Montis4x4
Done both front and rear and sensors best prices were from Famous 4x4 for Land Rover parts, louth and they arrived next day would advise always ordering the brake wear sensors as they become very fragile with age.
Paul Regards
Paul
Range Rover Classic
2x Freelander 3 doors
DiscoII V8
2x FFRR
RRS HSE TDV6 32.3 mpg average for the last 20K
Evoque when the quality is sorted
Post #321045 Sun Nov 13 2011 7:21pm
Bodsy
Site Sponsor
This may help you guys as well.
The Brembo fronts are as already shown in this thread, but the std ones and of course the rears are the same as the D3.
http://www.disco3.co.uk/gallery/thumbnails.php?album=4184
Always check for the latest version, currently 1.6a
Ian Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #321113 Mon Nov 14 2011 1:50pm
Macdaddy
Just thought i'd say thanks Thumbs Up
Just done my pads.... Took longer to take off the wheel than to change the pads. TDV8 RRS HST in Java - Gone
TDV6 RRS Autobiography in Bali blue - Gone
TDV6 RRS Autobiography Dynamic - Current
Post #379968 Tue Apr 09 2013 3:15pm
RRS-Spy
I am looking to change the pads on my front brembo brakes and this guide is really useful.
A quick question, other than the pads and one brake sensor, is there any other part I will need eg springs etc ?
Thanks Proud owner of a 2008 TDV8 HSE.....and an Audi A3 2.0T DSG Cab and a Porsche 911 Turbo (Mercedes W208 320 CLK and Mercedes W124 E220 Estate now gone)
Post #386946 Tue Jun 25 2013 11:41am
Macdaddy
Thanks
Nothing extra needed when i did it, You only need the sensor too if yours has triggered the light on the dash.
*EDIT... realise this post is a bit old now however i only got email notification today about a reply lol TDV8 RRS HST in Java - Gone
Post #386952 Tue Jun 25 2013 12:38pm
Simon58
England 2008 Range Rover Sport TDV6 HSE Galway Green
Great info Macdaddy, thanks helped me out a lot today, the brake pad warning light came on today, used this to change my front pads, now the dash light is staying on so I suppose I have to change the cable too? About to get into a sport
Post #391346 Fri Aug 09 2013 3:36pm
RR-moggle
Nice Very Happy Very Happy Very Happy
Post #433389 Sat Aug 16 2014 9:21pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
Did you also measure rotor thickness - anyone know what spec is for that ? If rotor is pretty smooth with no big ridges on outer edge it is probably OK to just change pads - but I thought you should turn rotor (if it is in spec still) or replace - with pads - if rotor is showing signs of wear ...
Plan to do my rears soon ...
Post #435965 Thu Sep 11 2014 3:22am
Nuclear Red
United Kingdom 2009 Range Rover Sport TDV6 SE Stornoway Grey
I would use axle stands on hard ground as well as a trolley jack to to the lift.
Nice and safe then.
Post #440616 Mon Oct 27 2014 3:39pm
nicka113
Is this the same for front and back?
Post #492739 Tue Apr 05 2016 9:21am
Bodsy
Site Sponsor
Backs are the same as in the brake bible (see link below) Bodsys Brake Bible
See it HERE
Post #492749 Tue Apr 05 2016 10:12am
amuquet
Thank you. This will come in handy.
Post #492764 Tue Apr 05 2016 11:51am
jatin22aug
Thanks
Post #571953 Sat Dec 29 2018 8:30pm
