![]() | Home > Technical > [FAQ] WARNING - DOES YOUR FRONT SUSPENSION KNOCK? |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
Ask them if this problem arose during pre-launch testing and if they are knowingly selling cars that are going to develop faults.
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
enzojnior is quite correct. The hydraulic knock which eminates from the DR system is totally different from the wear knock which eminates from worn anti-roll bar bushes and ball joints. The diagnosis for the DR knock is to rock the steering wheel from side to side violently at 20 mph. If a knock results, then the DR is at fault. The DR fuse should then be removed (see previous posts) and the test repeated. If the knock can still be induced then the problem is likely to be worn anti-roll bar bushes allowing the anti-roll bar to move side to side. If the knock is no longer present then it is the hydraulic system which LR claims to be "a characteristic of the vehicle" BUT IS CLEARLY NOT, AS IT DOES NOT HAPPEN ON EVERY VEHICLE FITTED WITH THE DR. The anti-roll bar bushes wear extremely quickly, especially if you regularly drive on rough roads eg Ireland or the Isle of Wight. Much has been said about the front ones wearing but the rear also wear. If left unattended both are likely to lead to premature failure of the anti-roll bar itself due to seals leaking - which eventually will come back and haunt LR in terms of warranty claims. Some enterprising LR specialist will probably do LR's job for them and commission a polybush which will stand up to the job. On a final note. Has anyone thought about a sending a petition letter to Mr Tata on behalf of all of us? For such a boring subject, just look and see how many people have read this topic to date! Simon.mcdonald I am happy for you to include my name Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Well folks just got my car back from the Dealer all squeaky clean. Thank you |
Come on LR - we love your cars but this is frustrating and could cost you in the future when people avoid the brand. 2005 Zambezi TDV6 - Gone but not forgotten
LR - Perhaps it's a good job I haven't found the need to do any off roading especially with flimsy ball joints |
Japseroony Member Since: 06 Feb 2008 Location: At home with a beer!!! Posts: 256 ![]() ![]() ![]() |
Just picked up my 08 HST after its first 15k service having only covered 11k.
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 ![]() ![]() ![]() |
Will are you still |
rmarinel Member Since: 03 Mar 2008 Location: Edinburgh Posts: 14 ![]() ![]() ![]() |
My dealer said exaxtly the same when in for its service last month/ Land Rover are aware of the ARC system problem which causes premature bush wear and apparently have 3 different University R&D departments looking at a solution!
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 ![]() ![]() |
TBH, both ![]() The trial comes to a close at the end of this week. Yes, its quieter, but it still makes a racket at times. If I was to give a percentage improvement, I would say 70%.....but there is still no getting away from the fact that it SHOULD NOT knock whatsoever. ![]() Update tomorrow. ![]() 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
deadly Member Since: 29 Nov 2008 Location: lancashire Posts: 9 ![]() ![]() ![]() |
hi folks,im brand new on here and appreciate all your rrs experience,especially on this topic.Ive just bought a january 2006 2.7hse (without dynamic control)from a non franchised dealer and guess what? knocking on front end!!! Warranty is up on end of jan09 so i intend to fire it back to my local main agent now. The noise does sound like a drop link rattle or anti roll bar,chatter type sound on uneven surfaces. Is this knock,be it droplink,bushes or ball joints under warranty at 50k miles? |
The simple answer is yes - covered under warranty. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
thats a relief jo,in to stealers on thursday.
The doc Member Since: 31 Oct 2006 Posts: 1173 ![]() ![]() |
Hi all, Just thought I'd pop in and say hello - hows the knock situation developing? |
I'm waiting to hear with bated breath if the new design ball joints have arrived for my booking on Tue |
