![]() | Home > General > Welcome to RRSPORT.CO.UK - say hello here! |
Rujhena Member Since: 24 Nov 2017 Location: Leeds Posts: 1 ![]() ![]() |
Someone please help,
Whisper90 Member Since: 27 Nov 2017 Location: London Posts: 3 ![]() ![]() ![]() |
Hi All
Whisper90, welcome to the forums. First step is to take the car back to the supplying person and get them to fix it under the warranty. It could be any of a number of things but suspect it might be the EGR/ Turbo. Ask them while you are there when the belts were last changed and if the oil pump has been changed as that iis a body off job and should be done at the same time as the belts. Don’t panic at “body off” as the car is designed to be detached from the chassis in about an hour with the help of a lift and some experience.the Bluetooth sounds like it might need the upgraded unit - contact member Bodsy on the forum as he can supply them 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Great. Thanks for the advice. The light is a bit of a worry. That said, I drove around in a CLK for 2 years with said light permanently on. Dealers couldn't find a fault. I will get in touch with the Bluetooth guru at some point. I'm guessing his BT upgrades wont cover things like music streaming. I believe that's a whole that's a whole different ball game. I did consider an aftermarket jobby but feel the need to enjoy the car as is |
beerbelly Member Since: 28 Nov 2017 Location: Teesside Posts: 27 ![]() ![]() ![]() |
hi folks newbie here from Teesside picking up a 07 rrs se on Sunday. my Mrs has always wanted one I have always liked the look but been scared off by unreliability rumors |
Discodave Member Since: 28 Nov 2017 Location: Tyne and wear Posts: 3 ![]() ![]() ![]() |
Hi everyone
District69 Member Since: 29 Nov 2017 Location: London Posts: 1 ![]() ![]() |
Hi
millsy123 Member Since: 02 Dec 2017 Location: bham Posts: 4 ![]() ![]() |
hi i have rrs ...im tryig to find out if i have dpf |
iaind Member Since: 04 Dec 2017 Location: cardiff Posts: 2 ![]() ![]() ![]() |
hi guys,
Millsy, which model year is the car - IIRC all RRS TDV6, SDv6 and TDV8 after 2011 or 2012 had DPFs, ie facelifted L320’s - I think too that diesel RRS’s with DPF’s have downward pointing exhaust outlets on the tail pipes, non DPF cars have straight out exhausts. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
qcnr Member Since: 07 Dec 2017 Location: Stavanger Posts: 40 ![]() ![]() ![]() |
Hello, my name is Quentin and I am a Land Rover
torcida1950 Member Since: 11 Dec 2017 Location: Split Posts: 6 ![]() ![]() ![]() |
Range rover Sport TDV8 3.6 from Split-Croatia
Mrme4u Member Since: 12 Dec 2017 Location: Papua New Guinea Posts: 7 ![]() ![]() ![]() |
Hi,
Ptchw Member Since: 27 Aug 2017 Location: Richmond Posts: 5 ![]() ![]() |
