![]() | Home > General > Auto lights on in daylight |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
Someone may have enabled Canada daylime lights. If the main beams don’t work when switch is off, that is probably the case.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
Do they come on as soon as ignition switched on? as could be set to "Scandinavian" in the CCF files, as dipped headlight come on as soon as engine is started, If I remember right "Canadian" setting light's don't come on until engine started, drive engaged and park brake released.
