![]() | Home > Technical > Tyre size change |
savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 154 ![]() ![]() |
Have at the moment 255/55/18 on my 09 2.7v6 RRS, will the Bridgestone 265/60/18 fit directly on my rims with no rubbing as there's a chap selling 5 tyres for £100 near new here in NZ. Cheers |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
I run 275/45 x 21" rim/tyres which are a very similar overall diam. to 265/60 x 18" 781mm for 275 and 775mm for the 265's and have no clearance/rubbing issues and that is with slightly lowered suspension as well, so don't think they would be a problem with clearance, but as you probably have 8J x 18" rims if they are original L/R one's, not really sure whether the 265 may be little wide, as personally not sure what max recommended width tyre is for a 8J rim.
Thanks Col. Original LR rims, maybe someone in the UK or Australia who has can answer this, won't buy the tyres till I find out, that's if there are not sold to someone else, Cheers. |
Have just found out via google search that the min rim is 7.5 inch and Max is 9.5 inches for the 265 60 18 tyres to fit. My rims being 8 inches. |
