Home > Technical > Tyre size change
savi18
New Zealand
Tyre size change
Have at the moment 255/55/18 on my 09 2.7v6 RRS, will the Bridgestone 265/60/18 fit directly on my rims with no rubbing as there's a chap selling 5 tyres for £100 near new here in NZ. Cheers
Post #646087 Sat Jan 04 2025 7:32pm
I run 275/45 x 21" rim/tyres which are a very similar overall diam. to 265/60 x 18" 781mm for 275 and 775mm for the 265's and have no clearance/rubbing issues and that is with slightly lowered suspension as well, so don't think they would be a problem with clearance, but as you probably have 8J x 18" rims if they are original L/R one's, not really sure whether the 265 may be little wide, as personally not sure what max recommended width tyre is for a 8J rim.
Post #646088 Sat Jan 04 2025 9:29pm
savi18
New Zealand
Thanks Col. Original LR rims, maybe someone in the UK or Australia who has can answer this, won't buy the tyres till I find out, that's if there are not sold to someone else, Cheers.
Post #646089 Sat Jan 04 2025 10:35pm
savi18
New Zealand
Have just found out via google search that the min rim is 7.5 inch and Max is 9.5 inches for the 265 60 18 tyres to fit. My rims being 8 inches.
Post #646090 Sat Jan 04 2025 11:05pm
