Home > Technical > Varying brake pressure whilst driving
RRSPORTL49430
United Kingdom 2013 Range Rover Sport SDV6 HSE Arctic Frost
Hi All,
I currently have an intermittent braking issue. Whereby if driving the brake feels normal and then all of a sudden Theres a drop in pressure and have to travel a lot further to get the same stopping pressure.
I’ve never had this before during ownership, I have checked and brake fluid seems fine, no leaks around the vehicle whatsoever.
does anyone have any ideas what could be causing this? The pads & disks were changed 3 months ago and the only work it has had done to it recently is 2no. Lower arms due to MOT failure
Post #645990 Mon Dec 30 2024 4:51pm
older models had an issue with engine Oil getting into the servo. (the vacume part)
You would remove the vac pipe, and dip a long white cable tie down, as a dip stick to see if oil was present.
probably not your issue, but worth mentioning incase
Post #645993 Mon Dec 30 2024 5:42pm
