Home > General > Brake piston flaking??
Dunc101
Hi all - it's been a while since I posted, apologies.
Im changing my discs and pads at the moment - no problem, but upon inspection of both front calipers, the pistons look like this - ie 'flaking'.
Is this normal?!
Im hoping the answer is either:
A) Yes, chill out!
B) No - change the pistons
C) No - change the caliper
D) Something else!
Preferably not C though.....please?! Smile
All comments welcome. Thankyou
Post #645262 Fri Nov 15 2024 9:13pm
NoExpert
E) Normal, but not in a good way. Replace the pistons with some hard anodized Frenkit pistons and seal kits. Not very expensive and they don’t flake.
 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #645268 Sat Nov 16 2024 7:31am
JonnyCJ
As above from no expert. If they flake at the seal you’ll lose pressure and probably get brake fluid on the disc.
Easy job to renew seals and pistons.
Post #645269 Sat Nov 16 2024 9:31am
Dunc101
Thanks NoExpert and JonnyCJ.
I'll reassemble as-is right now as the car is needed as the 'daily driver', and look at the Frenkit replacement pistons and seals asap.
Legends! Bow down Smile
Post #645270 Sat Nov 16 2024 10:02am
JonnyCJ
Here’s a thread for the calipers I did on my old V8 Vantage. Full detailed strip down and rebuild.
It’s the same process for most Brembos and especially the LR ones.
https://www.pistonheads.com/gassing/topic....;t=1866080
Post #645271 Sat Nov 16 2024 10:19am
NoExpert
The kits I bought were 246914 and had pistons, seals and bleeders for one calipers (you need two kits).
Post #645272 Sat Nov 16 2024 11:40am
