Home > General (L494) > Eye watering and difficult breathing in cabin
Rob Evans
United Kingdom 2013 Range Rover Sport SDV6 HSE Bonatti Grey
Hi, I have recently purchased a L494 Range Rover Sport. 2014 3.0 Diesel.
Fantastic car except I’m experiencing terrible problems with cabin fumes. These smell like burnt oil and are bad enough to burn the back of my throat and make my eyes water.
2 garages have looked at this and neither have solved it.
Please help
Post #644036 Tue Sep 03 2024 6:01pm
Disco_Mikey
EGR pipe, crossover pipe or a seal on one of the exhaust clamps
Post #644037 Tue Sep 03 2024 7:19pm
Rob Evans
Hi Mikey thank you so much for a swift reply . Is this something I could check from underneath?
Post #644038 Tue Sep 03 2024 7:27pm
Rob Evans
Do you think this would cause an acrid smell in the cabin and also a similar burnt oily smell in the engine bay even when the engine has been turned off ? Thank you
Post #644039 Tue Sep 03 2024 7:50pm
supernatural
Australia
i had something similar with my old car. have you checked the cabin air filter? might be worth a look, though im not sure if it'd cause such strong smells.
Post #644043 Wed Sep 04 2024 3:19am
Rob Evans
Thanks fon the idea, yes I’ve even replaced it . It’s a strong burnt oil smell and very evident under the bonnet , in fact even as you walk up to it .
Post #644048 Wed Sep 04 2024 6:16am
If any of those components have cracked and are leaking exhaust gas, that will smell in the engine bay and in the cabin as some of the air going in to the cabin could pick up some of that exhaust gas.
The EGR and crossover pipe aren't going to be easy to see without pulling some bits off - the crossover pipe runs across the back of the engine in front of the firewall, for example. 2012 SDV6 - it's missing a couple of cylinders
Post #644052 Wed Sep 04 2024 8:35am
Rob Evans
Well that would certainly tie in with the symptoms ! I will try to get underneath and have a look . I presume there isn’t a tool to sniff exhaust fumes? Once again thank you for your help. It’s all helping track down the cause 🙏
Post #644053 Wed Sep 04 2024 9:14am
Rob Evans
Ps has anyone out there replaced a EGR crossover pipe on a L494? Any idea of the difficulty and what’s involved?
Post #644058 Wed Sep 04 2024 2:00pm
Rob Evans
Hi guys, because the burnt oily smell is still very evident days after I’ve switched the engine off, may this suggest an oil leak somewhere? Just a thought
Post #644071 Thu Sep 05 2024 10:04am
Rob Evans
Hi everyone and thanks for your inputs. I paid 2 guys £500 each to solve my problem but without joy.
However in the end i rolled up my sleeves and tackled the problem myself. I am not a mechanic but I am a highly qualified engineer.
I traced the fault to number 6 diesel injector leaking at the base of it. I tried fitting new self to no avail. i eventually bought a re-seating tool from eBay . I re-seated it, fitted 2 washers instead of one and the problem has been solved. I jet cleaned the engine bay beneath the faulty injector of all the leaked diesel and the smell was cured
Post #646348 Sat Jan 18 2025 11:49am
Mac35
Scotland
The problem with fitting two copper washers instead of one is that the injector will now sit further into the cylinder head. I’m not sure on how far they actully protrude normally. But if it’s now sitting slightly into the head it could well start to either interfere with the spray pattern or erode and damage the head.
Post #646378 Sun Jan 19 2025 1:01pm
Rob Evans
Hi Mac, a very good point made but I estimate the thickness of the extra washer equates to the material I removed . ( approximately) …iIts been running super smooth for a while now so hopefully no connection between the two problems .
Once again, thank you for your input .
Post #646379 Sun Jan 19 2025 1:22pm
Rob Evans
We have good news 🙏…I took all the engine covers off etc and disconnected all the wires to the injectors …carefully measured the resistance across the 3 injectors on the near side bank . I injector showed a much higher resistance across the coil and interestingly, occasionally to ground also .Luckily I had a spare ( secondhand ) injector which I fitted and all is ok now!!!! Thanks for your help guys and hope this helps someone else at some point🙏
Post #646383 Sun Jan 19 2025 5:23pm
Karlp606
Hi Rob - I’ve got the same issue on injector 2 - leaky seal when the car gets upto temp and the old chuff chuff tap tap noise.
Do you have a link to the reseal kit you bought? Did you fit new o rings on the injector or just the washers under the clamp?
Post #647304 Sun Mar 16 2025 2:56pm
