Home > Maintenance & Modifications > Alternator & Belt 2008 TDV8 |
Cueball Member Since: 24 Jul 2024 Location: Cumbria Posts: 7 |
Hi all,
Thu Jul 25 2024 2:09pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4913 |
I'm not sure I understand?
Thu Jul 25 2024 4:30pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4952 |
The Alternator drive belt on a TDV8 does not drive the water pump just the Alternator and ARB pump + idler/tensioner if I remember right.
Thu Jul 25 2024 9:37pm |
Ahh so this is what I was thinking thank you for confirming this. I've tried to find some belt arrangements to show how it fits and runs around the different pulleys and idlers. The only ones I have come across seems to have the alternator on the main belt and not secondary.
Fri Jul 26 2024 12:24am |
Might need to double check, but L/R part no. of belt looks to be PQS500460. Pretty sure It was standard fitment on the TDV8 unless someone has bodged it up and removed the system, should be a resevoir for it on the O/S similar to the P/S one.
Fri Jul 26 2024 12:58am |
Perfect. Thank you very much 😊 |
Fri Jul 26 2024 10:36am |
Ok so further inspection with new knowledge I can see that it's the pump that has gone. You called this the ARB pump but I'm seeing it described as ACE pump. Are both correct? Seems like my repair bill has just gone up.
Fri Jul 26 2024 11:22am |
So I've finally got around to stripping it down and getting to the pulley but it's the pump that's gone. Whole shaft into the pump is wobbling and looks like casing is cracked.
Tue Aug 27 2024 12:20am |
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 46 |
ARB, ACE and Dynamic Response seem to be used interchangeably for the same bunch of gadgets that control the hydraulic sway bars.
Wed Aug 28 2024 12:18am |
Google RVB500060 £1500.00 for a genuine one from L/R that's 500 for the pump and 1000 for the pretty L/R box it comes in.
Wed Aug 28 2024 1:58am |
Haha. Thanks guys |
Wed Aug 28 2024 11:49pm |
Finally found myself a pump and me and a friend fit it on Sunday. Was not a fun job but feel the accomplishment.
Tue Oct 08 2024 6:30pm |
