Home > Maintenance & Modifications > Alternator & Belt 2008 TDV8
Cueball
United Kingdom 2008 Range Rover Sport TDV8 HSE Santorini Black
Hi all,
I have recently purchased my first Range Rover. It's a 2008 Range Rover Sport 3.6L TDV8. Really loving the car and the drive. I do have an exhaust manifold leak which sounds like a loose belt but will have to save some pounds for that job.
My current issue is my alternator went on me. Got the panel off and had a look and alternator pulley is stiff to turn and at an angle. I feel pretty confident changing this out however the belt is perplexing me as it's now off and I can't seem to find any information on a belt that doesn't run other components such as power steering and fan. Seems like everything else is still running. Is there a version where a belt only runs the alternator?
Thanks.
Post #643447 Thu Jul 25 2024 1:09pm
I'm not sure I understand?
Why do you want a belt that only runs the alternator? And What about the water pump?
Post #643448 Thu Jul 25 2024 3:30pm
The Alternator drive belt on a TDV8 does not drive the water pump just the Alternator and ARB pump + idler/tensioner if I remember right.
Post #643459 Thu Jul 25 2024 8:37pm
Cueball
Ahh so this is what I was thinking thank you for confirming this. I've tried to find some belt arrangements to show how it fits and runs around the different pulleys and idlers. The only ones I have come across seems to have the alternator on the main belt and not secondary.
Also would I definitely have an ARB pump?
Post #643464 Thu Jul 25 2024 11:24pm
Might need to double check, but L/R part no. of belt looks to be PQS500460. Pretty sure It was standard fitment on the TDV8 unless someone has bodged it up and removed the system, should be a resevoir for it on the O/S similar to the P/S one.
Post #643465 Thu Jul 25 2024 11:58pm
Cueball
Perfect. Thank you very much 😊
Post #643468 Fri Jul 26 2024 9:36am
Cueball
Ok so further inspection with new knowledge I can see that it's the pump that has gone. You called this the ARB pump but I'm seeing it described as ACE pump. Are both correct? Seems like my repair bill has just gone up.
I haven't yet started taking out the engine fan to gain access to the front yet, but would it be possible it is just the pulley come loose somehow and could just be tightened up? Never seen one out of the vehicle yet.
Thanks.
Post #643470 Fri Jul 26 2024 10:22am
Cueball
So I've finally got around to stripping it down and getting to the pulley but it's the pump that's gone. Whole shaft into the pump is wobbling and looks like casing is cracked.
Would anyone know the part number for this pump?
Post #643923 Mon Aug 26 2024 11:20pm
peterjj
Australia
ARB, ACE and Dynamic Response seem to be used interchangeably for the same bunch of gadgets that control the hydraulic sway bars.
Find all your part numbers here https://parts.jaguarlandroverclassic.com/p...and-rover/ Pete
2008 L320 TDV8
2022 Hilux Rugged-X
Post #643939 Tue Aug 27 2024 11:18pm
Google RVB500060 £1500.00 for a genuine one from L/R that's 500 for the pump and 1000 for the pretty L/R box it comes in. Rolling with laughter
Post #643940 Wed Aug 28 2024 12:58am
Cueball
Haha. Thanks guys Smile
Post #643959 Wed Aug 28 2024 10:49pm
Cueball
Finally found myself a pump and me and a friend fit it on Sunday. Was not a fun job but feel the accomplishment.
Thanks for the help guys Smile
Post #644620 Tue Oct 08 2024 5:30pm
