Home > General > ACE Fluid Change
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
ACE Fluid Change
Eh up all,
Finally managing to get some time to sort a few jobs on the list.
I did the power steering fluid change in May which went well and certainly needed doing.
I checked the ACE reservoir and for the life in me looks like Red ATF in there - so want to swop out ?
I believe it’s meant to be same spec as power steering fluid
So any method to replacing this fluid, I’ve looked at the set up but drawn a blank as to how to approach this, having learned lessons early on these cars I’m better to ask first than risk tinkering and Causing a cock up👍
I’m also going to ask if there’s any risk in new fluid going in and swelling seals etc with new v old fluids
As always all inputs greatly appreciated
Post #642754 Thu Jun 20 2024 9:25pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
There is a small filter ..some where under the rear in the valve block which can be replaced ..dont know if removing it will let it drain.
https://www.ebay.co.uk/itm/355368137675 Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #642756 Fri Jun 21 2024 7:55am
TTR
Eh up pistnbroke
Read about that and seen the filter and recon I can get at that and replace it easily enough.
Just lack of info on how the valve block actually works and how you can flush the system out.
I’m going to assume the valve block controls front and rear operation therefore the valves need a signal to open up otherwise default position is closed so no fluid transfer
If I’m correct I have no idea how you can circulate the fluid around the system???
I do love these vehicles 🤬
All advice more than welcome and I’ll post any pictures once/if I manage to do this job
Post #642757 Fri Jun 21 2024 8:30am
Just removeing the filter will only drain about a teaspoon full.
Post #642760 Fri Jun 21 2024 10:15am
TTR
Eh up Col
Yup that’s what I’ve read too, I’m confident in changing filter as appears limited risk of air entering system which I’m assuming is self bleeding.
Still working on figuring out the rest 🤔
Post #642761 Fri Jun 21 2024 10:21am
Woody91
United Kingdom 2012 Range Rover Sport SDV6 HSE Fuji White
Following with interest, I've had the filter and fluid on my eBay watch list for a while now as it's one of those jobs I've been meaning to do. My plan was to change the filter then periodically change the contents of the reservoir for fresh fluid.
Post #642762 Fri Jun 21 2024 12:14pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
I went to do my filter and fluid recently
Ebay filter is to big so I cleaned the old filter out and put it back in fluid was pretty clean as iv flushed it a few times
Post #642765 Fri Jun 21 2024 2:25pm
Meiang
I change my ACE fluid and filter every two years. After removing the valve block plug use an M6 thread screw to pull out the filter and put a new one in. Then use a syringe to empty the ACE reservoir and fill it with new fluid - start the vehicle and run it for a few minutes, then repeat the process about 5 times. I use Castrol Transmax Z ATF. I also use it for my power steering fluid which I change at the same time
Post #642766 Fri Jun 21 2024 2:28pm
Woody91
Could you share which listing you used to buy the filter please.
Post #642770 Fri Jun 21 2024 4:08pm
Meiang
RVJ100010
I bought myself a supply a few years ago from Bearmach. I only bought genuine (when the price was right)
Post #642772 Fri Jun 21 2024 5:09pm
TTR
Eh up Lrstaylor
Cheers for this least I know I can clean mine out if needed, assume carb or brake cleaner will do it🤔
Meiang
Cracking thanks for the advice, was tempted to see if I could flush it through like my power steering but as soon as I figured out how the valve block worked thought I might have to gradually dilute the old fluid with new.
Just one question do you simply start the car and leave it running or do you need to drive it to encourage the ACE system to work 😁
Cheers for all the advice 👍
Post #642777 Fri Jun 21 2024 9:05pm
If I understand the L/R w/shop manual correctly, the oil does not circulate the system until the engine is running and the vehicle is moving to open the valves and move steering etc. so just changing the oil in the reservoir it is not doing much really, if you do not move the vehicle and simply change the oil several times in the reservoir you are just changing the same oil again, which is why you need some way of opening the valves in the valve block, i.e. £500.00 L/R special tool Rolling with laughter The reservoir holds 0.4 Liters the whole system holds 2.4 Liters.
Post #642778 Fri Jun 21 2024 9:21pm
TTR
Eh up Col
I thought as much - will need to “drive it like I stole it “ 😳👌 to encourage circulation otherwise valves must remain closed .
I’m guessing it might take a few more changes if system holds that much and reservoir only holds 400ml
Either way I know what I’m up against now
Thanks everyone 👍
Will try and post a few pictures of my attempt as usual
Post #642779 Fri Jun 21 2024 9:33pm
Those quantities are what is stated in the manual so assume they are about right, would have thought by now someone may have worked out a way of tricking the valves to open while stationary and use some sort of pressure bleeder tool. Hopefully someone may respond who has managed it, would be very useful I members I think
Post #642782 Fri Jun 21 2024 9:45pm
TTR
Eh up all,
Ordered same fluid as used on the power steering as I’ve checked and spec is same 👍
Now I know the filters a metal mesh I can see no reason why it cannot be flushed/ cleaned with alcohol or brake cleaner - let me know if I’m wrong 🤔
Plan is to clean filter then replace, empty reservoir , fill with clean fluid, run car around Italian style 😁😳
Empty reservoir- rinse and repeat a few times and see what colour I can get on the fluid
Will post update on method 😁
Thanks for everyone comments
I don’t think it’s possible to trick the valves in the central block to open without the proper diagnostic equipment 😤
Let you know how I get on 👍
Post #642791 Sat Jun 22 2024 6:09pm
