Home > General > Rust…. To fix or not to fix |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
what year is it? |
Sun Jun 09 2024 5:21pm |
Shaunm41 Member Since: 09 Jun 2024 Location: Yorkshire Posts: 6 |
It’s a 2007 TDV8 |
Sun Jun 09 2024 5:22pm |
https://new.lrcat.com/#!/12129/118992/118993/9455/119030
Sun Jun 09 2024 5:40pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 413 |
fail
Mon Jun 10 2024 6:05am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
Why will it fail? It's corrosion in bodywork that isn't in a prescribed area - it's not the chassis rail to which the suspension is attached. That area isn't the attachment point of the body on to the frame either. When the doors closed and the cill panel in place it's not presenting a sharp edge that could injure someone.
Mon Jun 10 2024 7:54am |
look on the DVLA site for the previous MOT advisories and see if corrosion in that area is noted.
Mon Jun 10 2024 7:57am |
Woody91 Member Since: 17 Feb 2024 Location: Norfolk Posts: 12 |
Chassis or not, it looks like it's within 30cm of a seatbelt mounting point, so would be a fail. |
Tue Jun 11 2024 8:01pm |
Good point, it might be within 300mm of a seat belt mount. If there is a real intention to sort it, I'd be tempted to put the cill cover back on and see whether it gets flagged. And then, either way, get it sorted but at least you'd have time if it doesn't get flagged at the test. 2012 SDV6 - it's missing a couple of cylinders
Tue Jun 11 2024 10:13pm |
Well….. to my surprise, it passed with no advisories 🥳 |
Fri Sep 27 2024 6:30am |
