Home > General > Rust…. To fix or not to fix
Shaunm41
Evening all…
So I’ve bought this pile of junk but have actually grown to quite like it and was wondering wether this is fixable or wether it will pass an mot like this until I find a decent welder to work their magic
It’s on the near side rear sill
All opinions welcome
Thanks
(For some reason the image is upside down and I can’t figure out how to change it)
Post #642519 Sun Jun 09 2024 4:48pm
karlos01
what year is it?
Post #642520 Sun Jun 09 2024 5:21pm
Shaunm41
It’s a 2007 TDV8
Post #642521 Sun Jun 09 2024 5:22pm
karlos01
https://new.lrcat.com/#!/12129/118992/118993/9455/119030
don't know if this link would be any use to you?
Post #642523 Sun Jun 09 2024 5:40pm
Pistnbroke
fail
If you still have some MOT then you are Ok but once it fails you are off the road except for taking it for repair however you would know if there is anything else to fix. Always listen to old people or when they die you will live on in ignorance.
Post #642531 Mon Jun 10 2024 6:05am
Why will it fail? It's corrosion in bodywork that isn't in a prescribed area - it's not the chassis rail to which the suspension is attached. That area isn't the attachment point of the body on to the frame either. When the doors closed and the cill panel in place it's not presenting a sharp edge that could injure someone.
Could be down the the MOT tester's interpretation. 2012 SDV6 - it's missing a couple of cylinders
Post #642535 Mon Jun 10 2024 7:54am
Pistnbroke
look on the DVLA site for the previous MOT advisories and see if corrosion in that area is noted.
they would say it weakens the vehicle structure Always listen to old people or when they die you will live on in ignorance.
Post #642536 Mon Jun 10 2024 7:57am
Woody91
United Kingdom 2012 Range Rover Sport SDV6 HSE Fuji White
Chassis or not, it looks like it's within 30cm of a seatbelt mounting point, so would be a fail.
Post #642566 Tue Jun 11 2024 8:01pm
Good point, it might be within 300mm of a seat belt mount. If there is a real intention to sort it, I'd be tempted to put the cill cover back on and see whether it gets flagged. And then, either way, get it sorted but at least you'd have time if it doesn't get flagged at the test. 2012 SDV6 - it's missing a couple of cylinders
Post #642571 Tue Jun 11 2024 10:13pm
Shaunm41
Well….. to my surprise, it passed with no advisories 🥳
Post #644431 Fri Sep 27 2024 6:30am
