Home > General (L461) > L461 D300 to D350 Power upgrade for £495 by LR Retrofits
jorosa
https://lr-retrofits.co.uk/l461-new-sport-1
Thought i’d post this for anyone that would be interested
Also if anyone has used them before or if active on this forum?
I rang a tuning company about the d300 and none of the tuners have been able to crack the ecu, so am bemused at how these guys are doing it.
Post #642260 Tue May 28 2024 7:28pm
Badgerfife
Interested. Did you get anywhere with this?
Post #642354 Mon Jun 03 2024 7:16am
jorosa
https://www.rrsport.co.uk/forum/post640709.html#640709
The link above is a post linked to the defender 2 forum, and I think the software is the same for configurable lighting and to do the engine upgrade. The software they refer to is autosvs.
https://autosvs.com
Be interested if anyone has the software or if anyone is brave enough to tinker with it on their car! I just know if I did it the car would be bricked! 2024 Range Rover Sport D300 Dynamic SE in Varesine Blue
2019 Mercedes E Class Estate E350d (Gone)
2017 Mercedes C43 Cabriolet
2013 Jaguar XF Estate 3.0d (Gone)
2016 Mercedes CLA Estate 220d (Gone)
2006 Range Rover Sport 4.2 Supercharged (Gone)
Post #642362 Mon Jun 03 2024 11:35am
Gabriel1980
Romania
Re: L461 D300 to D350 Power upgrade for £495 by LR Retrofit
Hi, I did it 3 months ago, everything is ok, I also activated park assist and many others. I recommend Venture, Ste is a special guy. I forgot, it can be done remotely..https://www.venture-automotive.co.uk/ It is not a remap but a factory upgrade, the engine is identical
Post #642369 Mon Jun 03 2024 4:46pm
jorosa
Thanks Gabriel, I’ll contact them Thumbs Up 2024 Range Rover Sport D300 Dynamic SE in Varesine Blue
Post #642370 Mon Jun 03 2024 4:59pm
Gabriel1980
Romania
You are welcome.
Post #642371 Mon Jun 03 2024 5:04pm
RabJ
The engine is the same but the cooling etc is upgraded by Landrover for the more powerful version. Defiantly taking a chance doing this.
Post #642377 Mon Jun 03 2024 7:43pm
Gabriel1980
Romania
Hello, do you have any additional data? It's a bit hard to believe that LR designed the cooling differently. I haven't encountered any increases in the temperature of the coolant. It's only a 50 hp increase
Post #642387 Tue Jun 04 2024 4:01am
If it's done remotely, how is it not a remap? Even putting JLR's settings from the D350 in to the D300's ECU is mapping it. If they changed physical components then one could see the argument that it's a "factory upgrade", but they don't, so how is it not a remap?
And an engine giving 50hp more power is also going to be generating about 100hp more heat. The cooling system might be ok with that, especially in less warm climates. 2012 SDV6 - it's missing a couple of cylinders
Post #642388 Tue Jun 04 2024 7:36am
Autobiography
It’s a common misconception that the D350 is ‘just’ changes to the ECU. As others have alluded to, there are many physical component differences and given historical challenges with Ingenium engines and longevity, this is a massive gamble.
Post #642389 Tue Jun 04 2024 7:38am
Badgerfife
I'm intrigued. Can anyone share the data and evidence of the physical component and adjustments between the D300 and D350 engine and auxiliary components?
It then converts a gamble into a calculated risk.
Thanks in advance.
Post #642391 Tue Jun 04 2024 8:06am
The same engine has three outputs - 250, 300, 350 - doesn't it? How would a manufacturer have that range of outputs without making changes somewhere? The only way would be to build them all as 350 units and then "de-map" the lower output units. That would be an expensive way of doing things because the lower power outputs sell for quite a bit less.
It could be as simple as different radiators and pipe sizes to ensure adequate cooling, but it could be revised internal components too - the D350 has over 100lbft more torque than the D250, after all. 2012 SDV6 - it's missing a couple of cylinders
Post #642396 Tue Jun 04 2024 9:27am
RabJ
[quote="Gabriel1980"]Hello, do you have any additional data? It's a bit hard to believe that LR designed the cooling differently. I haven't encountered any increases in the temperature of the coolant. It's only a 50 hp increase[/quot
I have been driving a D300 Defender for the past two and a half years before buying the RRS. All the same things were discussed on their forum. A 300 and a 250 is the same engine, just detuned. Well between cars the dealer loaned me a D250 Defender and the first thing I noticed was that it fewer radiators. My D300 had two more in the corners of the front bumper for a start. When you up the boost to get more power you also get more heat so that needs taken care of. On the other hand as you are unlikely to regularly use the extra power you will probably get away with it, unless you're doing some heavy towing, but then what's the point if your hardly ever going to use the extra horses??
Post #642405 Tue Jun 04 2024 5:12pm
Badgerfife
Thanks for the above. Helpful on the D250 and D300. I'm still trying to establish the facts on the D300 to D350.
I have reached out to a the lead engineer for the Ford engine previously supplied to JLR and AM.
He is exploring his engineering network at JLR.
Let's see what I can unearth.
I am no expert.
Post #642408 Tue Jun 04 2024 6:11pm
RabJ
I would imagine D300 to D350 would be similar. Added cooling for the higher stressed engine and probably the gearbox as well. As I've said, unless youre towing, or a boy racer, you're unlikely to stress the engine any more than the D300 in normal driving.
Post #642413 Tue Jun 04 2024 8:19pm
