![]() | Home > General (L494) > Sunroof Drain Pipe Corrosion and Leak |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 272 ![]() |
Yes quite an easy fix - check here Ive posted a few threads about my fix
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 159 ![]() ![]() ![]() |
Thanks Karl - that’s very helpful.
Check here and also search youtube one guy has done the same repair on a L405 |
Thanks again but I can't find any videos or text on how to bypass/block-up the drain holes and install what "Pontoon" describes as a "plastic drain" to allow the water to drain outside the car. He seems to make it sound like a very simple fix so I'm keen to explore this before dropping the roof lining and doing one of the other fixes I've seen on YouTube!
Thank you Karl - I’ve seen that one but that’s the “full” job and from what I understand, this guy called Pontoon has managed to block up the drain holes entirely and somehow install a new drain tube under the plastic trim that runs the length of the car. I’ll try to message him and ask for clearer instructions! Will post them here if I manage it.
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 ![]() ![]() |
Hi All
Wow great write up!
RR55 Member Since: 30 Apr 2024 Location: Down Posts: 10 ![]() ![]() |
Hi, just been reading this as I've heard about the issue but don't have it, at least I don't think so |
Cheers I would take the time to have a look, as prevention is better than cure, just incase you flood the amp and electrics or stain the headlining if its light colour.
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1875 ![]() ![]() |
Does this only apply to opening sun roofs or are there drains on a fixed panoramic roof? 2023 P440e SE Dynamic on order -cancelled
Not sure I think the fixed still has the same set up on the roof side so maybe it does.
