Home > General (L494) > Sunroof Drain Pipe Corrosion and Leak |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 214 |
Yes quite an easy fix - check here Ive posted a few threads about my fix
Tue May 14 2024 8:49am |
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 158 |
Thanks Karl - that’s very helpful.
Tue May 14 2024 10:02am |
Check here and also search youtube one guy has done the same repair on a L405 |
Tue May 14 2024 10:11am |
Thanks again but I can't find any videos or text on how to bypass/block-up the drain holes and install what "Pontoon" describes as a "plastic drain" to allow the water to drain outside the car. He seems to make it sound like a very simple fix so I'm keen to explore this before dropping the roof lining and doing one of the other fixes I've seen on YouTube!
Tue May 14 2024 11:59am |
Tue May 14 2024 12:08pm |
Thank you Karl - I’ve seen that one but that’s the “full” job and from what I understand, this guy called Pontoon has managed to block up the drain holes entirely and somehow install a new drain tube under the plastic trim that runs the length of the car. I’ll try to message him and ask for clearer instructions! Will post them here if I manage it.
Tue May 14 2024 12:29pm |
