![]() | Home > Maintenance & Modifications > Live feeds off the GAP 11D MAP and MAF sensors |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
I think the default value/maximum MAF value on my Jag is 399 Kg/ph , so maybe engines aren't expected to exceed this? |
Cchewy Member Since: 16 Apr 2024 Location: Surrey Posts: 5 ![]() ![]() ![]() |
Then I suppose if this in fact the case which is reasonable given the table is set at these values for a reason, the engine is experiencing over boost and is shutting itself down for protection.
