![]() | Home > Technical > Range Rover Sport 3.6 TDV8 Hse Possible Turbo Failure |
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 49 ![]() ![]() |
Compression and leakdown test before starting other work just in case shrapnel has gotten in the bores and the engine needs reconditioning first. Pete
RJocall Member Since: 22 Feb 2024 Location: coventry Posts: 2 ![]() ![]() |
Hi Pete,
Jellis39 Member Since: 21 Apr 2019 Location: Melton Mowbray Posts: 64 ![]() ![]() |
If turbos are seized then it will starve the engine of air, I hear they can be done body on but I wouldn’t fancy it. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9025 ![]() ![]() ![]() |
Can be done body-on but easier and much more likely to be correctly done when body-off.
