Home > Technical > Range Rover Sport 3.6 TDV8 Hse Possible Turbo Failure |
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 48 |
Compression and leakdown test before starting other work just in case shrapnel has gotten in the bores and the engine needs reconditioning first. Pete
Thu Feb 22 2024 10:18pm |
RJocall Member Since: 22 Feb 2024 Location: coventry Posts: 2 |
Hi Pete,
Sun Feb 25 2024 11:02am |
Jellis39 Member Since: 21 Apr 2019 Location: Melton Mowbray Posts: 64 |
If turbos are seized then it will starve the engine of air, I hear they can be done body on but I wouldn’t fancy it. |
Tue Feb 27 2024 7:04pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Can be done body-on but easier and much more likely to be correctly done when body-off.
Tue Feb 27 2024 11:26pm |
