Home > Faults & Fixes > Stripped oil pump bolt on 2.7
Jacko29690
England 2005 Range Rover Sport TDV6 HSE Stornoway Grey
Good evening all,
I have just replaced oil pump to the updated version on my 2.7 MY 05.
Clearly it was all going too well, final Bolt, final torque and it’s snapped.
I’ve tried to remove it, which has now resulted in a removal tool being lodged and snapped inside the snapped bolt.
Where do I go from here? Last thing I want to do is just leave it, but at this point I can’t imagine it’ll be overly easy to remove a removal tool on top.
Any help / suggestions are welcome.
Post #639232 Sun Jan 28 2024 10:12pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Photograph Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #639234 Mon Jan 29 2024 7:45am
Pistnbroke
The classic way is to put a steel washer around it and weld the stub to the washer then put a large nut on top and weld inside the nut ...then wind it out Ha Ha good luck
Send us a photo Always listen to old people or when they die you will live on in ignorance.
Post #639235 Mon Jan 29 2024 7:50am
