![]() | Home > Faults & Fixes > Stripped oil pump bolt on 2.7 |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 440 ![]() ![]() ![]() |
Photograph Always listen to old people or when they die you will live on in ignorance.
The classic way is to put a steel washer around it and weld the stub to the washer then put a large nut on top and weld inside the nut ...then wind it out Ha Ha good luck
