Home > Technical > Spark Plug Removal
skid1963
Spark Plug Removal
Hi all
Just had my 2006 4.2 S/C serviced and MOT'd at my local indie.....sailed through with no advisories, however.....
The mechanic said he hasn't changed the spark plugs that were in the service kit as he was scared of breaking the old ones removing them, said they were incredibly tight.
He also explained that the reason this can happen is because of all the carbon/crud build up on the bottom of the plug thread which actually protrudes slightly into the engine block prevents the thread from turning.
So my question is is there an additive that i can add to the fuel to help clean the thread to enable easier removal?
I should add i only ever use BP Momentum or Shell Optimum fuel
Is this a common problem and is there any advice from you good people out there?
Also i do not have any issues with the current plugs
TIA 2015 L494 SDV6 3.0 HSE Loire Blue
2006 L320 4.2 Supercharged
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #639190 Sat Jan 27 2024 2:52pm
Not heard this before
One way to get plugs out is to get the engine nice and hot and then try and remove them.
Keep working them a bit at a time and restart engine, and spray wd40 down if you do get them moving a bit
Maybe a job for the summer
Post #639191 Sat Jan 27 2024 4:06pm
skid1963
Thanks Andy
He is an ex JLR mechanic so i'm sure he's seen it before
Will give it a go later in the year 2015 L494 SDV6 3.0 HSE Loire Blue
Post #639194 Sat Jan 27 2024 4:46pm
Disco_Mikey
Never had an issue with 4.2/4.4 plugs... Confused
Post #639195 Sat Jan 27 2024 4:55pm
skid1963
Do they have torque setting?? 2015 L494 SDV6 3.0 HSE Loire Blue
Post #639196 Sat Jan 27 2024 5:25pm
Disco_Mikey
27Nm Thumbs Up
Post #639199 Sat Jan 27 2024 8:15pm
Mafya
United Kingdom 2010 Range Rover Sport TDV8 HSE Lux Buckingham Blue
I would spray WD40 on them all and leave it till the weather gets warmer…
Post #639205 Sun Jan 28 2024 12:05am
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Iv done both our 4.2 sc and 4.4 na without issue they were tight but once you crack it off they came out pretty easy. Spraying wd40 down won't do much with the plug sealing ring down there. Hot engine is best way forward.
?feature=shared
Post #639220 Sun Jan 28 2024 7:35pm
skid1963
Thanks for that youtube link buddy, i notice he says to change them when the engine is cold because it's an aluminium head, not hot as you suggest 2015 L494 SDV6 3.0 HSE Loire Blue
Post #639309 Fri Feb 02 2024 12:21am
I think you will get a lot of different opinions about that, personally when I did my 5.0L I removed the plugs with the engine warm and they came out no problem, but replaced them with the engine cold due to different expansion rates between aluminum and steel, my logic was you will get a more accurate torque reading when they are both cold.
Post #639310 Fri Feb 02 2024 1:26am
Lrstaylor
Aa col says everyone has their preferd method. Yes the heads ally same as motorbikes which iv had for over 40 years so I'm use to changing out spark plugs and always from a warm/hot engine.
Only down side is its so tight in there you do burn a bit of skin Laughing
Post #639312 Fri Feb 02 2024 8:09am
