Home > Technical > Spark Plug Removal |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
Not heard this before
Sat Jan 27 2024 4:06pm |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 202 |
Thanks Andy
Sat Jan 27 2024 4:46pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Never had an issue with 4.2/4.4 plugs... |
Sat Jan 27 2024 4:55pm |
Do they have torque setting?? 2015 L494 SDV6 3.0 HSE Dynamic
Sat Jan 27 2024 5:25pm |
27Nm |
Sat Jan 27 2024 8:15pm |
Mafya Member Since: 05 May 2020 Location: Sheffield Posts: 46 |
I would spray WD40 on them all and leave it till the weather gets warmer… |
Sun Jan 28 2024 12:05am |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 341 |
Iv done both our 4.2 sc and 4.4 na without issue they were tight but once you crack it off they came out pretty easy. Spraying wd40 down won't do much with the plug sealing ring down there. Hot engine is best way forward.
Sun Jan 28 2024 7:35pm |
Thanks for that youtube link buddy, i notice he says to change them when the engine is cold because it's an aluminium head, not hot as you suggest 2015 L494 SDV6 3.0 HSE Dynamic
Fri Feb 02 2024 12:21am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
I think you will get a lot of different opinions about that, personally when I did my 5.0L I removed the plugs with the engine warm and they came out no problem, but replaced them with the engine cold due to different expansion rates between aluminum and steel, my logic was you will get a more accurate torque reading when they are both cold.
Fri Feb 02 2024 1:26am |
Aa col says everyone has their preferd method. Yes the heads ally same as motorbikes which iv had for over 40 years so I'm use to changing out spark plugs and always from a warm/hot engine.
Fri Feb 02 2024 8:09am |
