![]() | Home > Technical > Spark Plug Removal |
Not heard this before
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 213 ![]() ![]() ![]() |
Thanks Andy
Never had an issue with 4.2/4.4 plugs... |
Do they have torque setting?? 2015 L494 SDV6 3.0 HSE Loire Blue
27Nm |
Mafya Member Since: 05 May 2020 Location: Sheffield Posts: 46 ![]() ![]() ![]() |
I would spray WD40 on them all and leave it till the weather gets warmer… |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Iv done both our 4.2 sc and 4.4 na without issue they were tight but once you crack it off they came out pretty easy. Spraying wd40 down won't do much with the plug sealing ring down there. Hot engine is best way forward.
Thanks for that youtube link buddy, i notice he says to change them when the engine is cold because it's an aluminium head, not hot as you suggest 2015 L494 SDV6 3.0 HSE Loire Blue
I think you will get a lot of different opinions about that, personally when I did my 5.0L I removed the plugs with the engine warm and they came out no problem, but replaced them with the engine cold due to different expansion rates between aluminum and steel, my logic was you will get a more accurate torque reading when they are both cold.
Aa col says everyone has their preferd method. Yes the heads ally same as motorbikes which iv had for over 40 years so I'm use to changing out spark plugs and always from a warm/hot engine.
