![]() | Home > Technical > Removing heater plugs hot/cold ? The 5 K resistor. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
https://www.disco3.co.uk/forum/topic153396...p;start=60
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
https://disco3.co.uk/forum/topic191038.html
Granted the GP are on a lot for optimum whatever.
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 425 ![]() ![]() ![]() |
I am engaged on a full exploration of this system.
ppl have done it before you.
be careful not to confuse RRS and Disco sensors. Mine is 16k at 3 deg and 10k takes it to 59 c Always listen to old people or when they die you will live on in ignorance.
If you have a 2.7 the sensors should be the same. Unless the EU4 engine with the sensor by the airbox has different readings |
Until I have this cracked I am not going to comment further. Always listen to old people or when they die you will live on in ignorance.
New Year’s resolution? |
