Home > Technical > Removing heater plugs hot/cold ? The 5 K resistor.
https://www.disco3.co.uk/forum/topic153396...p;start=60
I’m sure flapper did a guide
Post #638938 Thu Jan 18 2024 10:48pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
https://disco3.co.uk/forum/topic191038.html
Have a read iv posted in this thread as well to help others for this mod to over come the failed glow plug issue.
Seeing as timed climate was an option on D4s its no real difference fitting this to a d3 difference being its not timed you choose when you want to use it.
Good luck 👍
Post #638959 Fri Jan 19 2024 4:43pm
riverblanche
Andy K wrote:
some have to pay £700 to get them changed.
although many can pay nearer half that Whistle
Do agree you can only spend money once so you choice where to spend it
also agree with RRS and as I said GP's are used a lot more than just starting so if there not working, the engine is not running at its optimum ( oh hold on Landrover Rolling Eyes )
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #638961 Fri Jan 19 2024 7:50pm
Granted the GP are on a lot for optimum whatever.
But having driven one around not knowning the gp’s had failed, and then replacing them I noticed no difference what so ever.
I would notice more difference running 2so Rolling with laughter
Post #638962 Fri Jan 19 2024 7:58pm
Pistnbroke
I am engaged on a full exploration of this system.
I can tell you that poring hot water on the temp sensor raises the temp by 8 deg C ( I have a digital display for engine temp)
10k is not the right value .....its more like 270k ohms (270 thousand) to raise it a similar amount to the hot water.
The temp sensor on my 2.7 is on the driver side in the top radiator hose near the air flow meter.
More to follow Always listen to old people or when they die you will live on in ignorance.
Post #638966 Sat Jan 20 2024 12:43pm
ppl have done it before you.
2K or 5K resistors are known to work. and make the ecu read hotter (and I assume inject more? fuel to make it start)
On a freezing day, a 10K resistor in parallel with sensor, only makes the ecu read ~1C. So this is why it doesn't work
https://www.disco3.co.uk/forum/topic178409.html
https://www.disco3.co.uk/forum/coolant-tem...light=glow
Post #638970 Sat Jan 20 2024 2:08pm
Pistnbroke
be careful not to confuse RRS and Disco sensors. Mine is 16k at 3 deg and 10k takes it to 59 c Always listen to old people or when they die you will live on in ignorance.
Post #638971 Sat Jan 20 2024 2:46pm
If you have a 2.7 the sensors should be the same. Unless the EU4 engine with the sensor by the airbox has different readings
Post #638972 Sat Jan 20 2024 3:02pm
Pistnbroke
Until I have this cracked I am not going to comment further. Always listen to old people or when they die you will live on in ignorance.
Post #638973 Sat Jan 20 2024 3:06pm
New Year’s resolution? Rolling with laughter
Post #638974 Sat Jan 20 2024 3:17pm
