![]() | Home > Technical > Removing heater plugs hot/cold ? The 5 K resistor. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Can of Easy Start in the boot, knock a little bit when it fires up though |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Your best bet long term is to use the cars fbh to pre warm the engine and defrost your car long before you want to use it via a simple remote and over ride device.
You need this to over ride the w bus function on the car to activate your fbh
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 440 ![]() ![]() ![]() |
I think Col has breathed in too much ether.
Watched a video on LR time showing how he failed to get any of the glow plugs out so I decided on this .......Measure the current drawn by each side at the fuse for each bank to get an idea of how many are working . any one know how much current they draw ?
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
I changed glow plugs on a 2.7 TDV6 LR3. Four of the six glow plugs broke. Managed to get them all out with some major time and effort via a few extraction kits. Had to pull the LH inlet manifold off and remove an injector on the right side when the tip fell into the cylinder (retrieved with a magnet). I don’t envy anybody doing that job. The new glow plugs were like my 3.0 TDV6 with thicker walls. Installed them with lots of copper spray. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi,
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
Making water temp hotter works.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
As ever, the best approach is to do the correct job correctly. 2012 SDV6 - it's missing a couple of cylinders
I refer to my previous answer ........to many horror stories doing the glow plugs when a simply 10 minute fix attaching the remote fbh device solves the problem warms the car and defrost it at the same time. As long as you remember to switch it on 15/20 mins before you want to use the car your good to go.
[quote="RRSTDV8"]As ever, the best approach is to do the correct job correctly.
Every problem in NZ/AU can be solved with silicone ...I know i lived there for 10 years ...but not this one Always listen to old people or when they die you will live on in ignorance.
Well some ppl have to pay £700 to get them changed.
The glow plugs aren't just used for cold starting, they're used to control emissions and help the thing run when the engine is idling and cold.
