![]() | Home > General > Rear seatbelt mod |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 421 ![]() ![]() ![]() |
As the belts get older the fabric gumms up with dirt ....clean full length with detergent dry and spray with silicone spray ( not wd40) they will then run back fine and you wont get the rattle Always listen to old people or when they die you will live on in ignorance.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9022 ![]() ![]() ![]() |
My MY08 TDV8 had a plastic clip on a bit of webbing that held the rear belt in place to stop it moving around or getting caught behind the seat when it was folded down to make a flat load bay. Just another of those really good little details I miss on my MY12 SDV6 that I had on my MY08 TDV8. I assume it was deleted to save JLR a couple of quid. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5041 ![]() ![]() ![]() |
Never did really workout why they did away with that clip on the facelift cars, as said probably saved 10p per vehicle. Fortunately I don't have rear seat passengers very often these day's so just leave mine plugged in.
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 166 ![]() ![]() ![]() |
Eh up all
The problem is I don't think they are listed separate in the parts list as they are sewn into the seat trim, but not totally sure on that one, so you may have to find a a earlier model in a breakers yard to get them.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5019 ![]() ![]() ![]() |
Yours will only be a problem if you put the seats down |
Eh up all
