Home > General > Rear seatbelt mod
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Rear seatbelt mod
Eh up all,
For some time the rear seat belt has dropped to the side and “ knocks” on the trim 🤬
Why there’s no clip to retain it ive no idea.🤔
So being bored today took a piece of webbing from an old rusk sack and modded up a retainer to trial.
Looped it around the belt then temp fix around the headrest which actually looks ok
If anyone has done anything any better let me know.
Worked a treat let’s see how it lasts - will modify if needed but no more rattling so far 😁👍
Cheers all
Post #638798 Sun Jan 14 2024 7:02pm
Pistnbroke
As the belts get older the fabric gumms up with dirt ....clean full length with detergent dry and spray with silicone spray ( not wd40) they will then run back fine and you wont get the rattle Always listen to old people or when they die you will live on in ignorance.
Post #638800 Sun Jan 14 2024 7:24pm
Re: Rear seatbelt mod
My MY08 TDV8 had a plastic clip on a bit of webbing that held the rear belt in place to stop it moving around or getting caught behind the seat when it was folded down to make a flat load bay.
Just another of those really good little details I miss on my MY12 SDV6 that I had on my MY08 TDV8.
I assume it was deleted to save JLR a couple of quid. 2012 SDV6 - it's missing a couple of cylinders
Post #638802 Sun Jan 14 2024 7:50pm
Never did really workout why they did away with that clip on the facelift cars, as said probably saved 10p per vehicle. Fortunately I don't have rear seat passengers very often these day's so just leave mine plugged in.
Post #638809 Sun Jan 14 2024 9:21pm
TTR
Eh up all
Never realised the prior year models had a clip, can you retrofit it rather than my “mod”
Might look and work better in long term
Post #638810 Sun Jan 14 2024 9:31pm
The problem is I don't think they are listed separate in the parts list as they are sewn into the seat trim, but not totally sure on that one, so you may have to find a a earlier model in a breakers yard to get them.
Post #638811 Sun Jan 14 2024 9:36pm
Yours will only be a problem if you put the seats down
Post #638813 Sun Jan 14 2024 10:05pm
Post #638820 Sun Jan 14 2024 11:21pm
TTR
Eh up all
Andy k - made these with Velcro so I can easily unclip 👍
Col - there ideal, I can mod something easily if I can get the plastic holders - will look on eBay 👍
Cheers all
Post #638846 Mon Jan 15 2024 9:00pm
