Home > Technical > Adding two stroke oil to fuel. yes/no
Page 1 of 4 1234>
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Read about this ..anyone tried it and it what ratio. Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #638560 Sat Jan 06 2024 8:53am
jimbg
https://www.rrsport.co.uk/forum/topic54001...two+stroke 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #638561 Sat Jan 06 2024 9:34am
Pistnbroke
Thanks but does not answer the question Always listen to old people or when they die you will live on in ignorance.
Post #638564 Sat Jan 06 2024 9:59am
jimbg
Probaly not, nor in the other 43 posts on the subject!
I guess there is no definitive answer. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #638567 Sat Jan 06 2024 10:50am
Pistnbroke
I think I read 400ml to a full tank Which is 200;1 which sounds a bit high Always listen to old people or when they die you will live on in ignorance.
Post #638569 Sat Jan 06 2024 10:54am
Pistnbroke
Post #638570 Sat Jan 06 2024 10:56am
Sounds the recommended ratio.
I use it now and again. Ideally every other tank full. But that works out expensive.
You should be able to hear the difference at the top end of engine.
Post #638571 Sat Jan 06 2024 11:35am
Lindab
http://www.freel2.com/forum/topic22434.html?highlight=yamahafan
Have a read of this Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #638572 Sat Jan 06 2024 11:54am
Brian Considine
I used to use Millers & never supermarket diesel.
When the MB Vito came out a mate & I bought one each - he used supermarket diesel & no additives.
I used premium fule & Millers.
He had new imjectors every 50k miles...............
I never had anything on the engine replaced (apart from oil & filters) and the engine was as good as new after 250k miles (tinworm was rampant though).
That's my experience, however, thesedays I use mineral two-stroke as engines that were built nearly 20 years ago were designed for diesel with sulphur (which acts as a lubricant for injection components) & of course the diesel you get thesedays does not contain sulphur. 2006 RRS 2.7 HSE.
Post #638575 Sat Jan 06 2024 2:16pm
Stevepd
I also use it and have done so since early on after the purchase of the car, some 7 years ago. From my experience it did nothing for the MPG, it did make it quieter and come MOT my emissions are incredibly low. Regarding the question its 200:1 I use. I've got a used water bottle with a long neck and have done the arithmetic and marked the bottle. It gets topped up to the mark. I put it in the tank whilst getting the disposable pump glove and then fill up. I only use regular shell diesel. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #638576 Sat Jan 06 2024 3:28pm
Pistnbroke
So there we have it 200:1...I was planning to use i on my next long trip across europe . Always listen to old people or when they die you will live on in ignorance.
Post #638579 Sat Jan 06 2024 4:34pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Nothing wrong with adding to a tank full it was a common practice for me when running our old tdi on veg oil and then our tdv6 d3 on derv. Mind you I ran the old tdi on all sorts of stuff and it's still going at over 250k miles on original engine and injectors
Post #638583 Sat Jan 06 2024 7:59pm
Total snake oil nonsense.
It started with an internet post about using it and it snowballed - no actual empirical evidence just a load of supposition and anecdote. It's the QAnon of engines, basically.
Use good fuel. Change the oil regularly. Use decent oil and filters. Anything else is bunkum. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #638587 Sun Jan 07 2024 12:23am
Dave B
We used to use it to great effect on an old straight 6, 3litre Opel Senator petrol engine.
Much much quieter, especially on start up, and did improve the mpg which could be diabolical if driven with haste.
However, that was not a high pressure fuel injection system, so the lubrication element was appreciated.
Not sure it would have the same effect on the modern precision high pressure systems we have now though.
Dave 2010 3.6 TDV8 HSE (Gone)
Post #638591 Sun Jan 07 2024 10:11am
Brian Considine
Well that's you opinion, to which you are entiltled too, but then again you seem to have to have an opinion on almost everything.
A local to me MOT Station often gets diesels that just fail the smoke test** - their advice is to run some two-stroke or Whynns through with a couple of tankfuls - guess what ? second time they pass. So, IMHO that quantifies as "empirical evedence".
** including well maintained diesels running on decent branded fuel.
FWIW I've run new diesels for the past 30 years or so using either Millers or two-stroke - every single one has covered 250/350kplus miles, still running well and never, ever an engine issue with any of them. Wheras other people I know, who don't use additives have issues.
What it boils down to is those that use additives will continue to do so (after all it cannot do any harm).
Do you have any "empirical evedence" to the contrary ?
Those that are against additives will not use them.
You contradict yourself anyway by promoting "decent fuel" because the fuel companies themselves tell us they put additives in it ! 2006 RRS 2.7 HSE.
Post #638594 Sun Jan 07 2024 12:15pm
Page 1 of 4 1234>
